04 Rancher 400FGA - diode question - Honda ATV Forum
post #1 of 13 (permalink) Old 04-25-2012, 08:20 AM Thread Starter
mdec950's Avatar
Liked: 4 times
Does anyone know the part number of the 2 diodes that are in the wire harness of a 2004 400 rancher fga wire harness ?
they are 2 prong - there are 2 hidden in the wraps of the harness close to the gas tank
not the one that is installed into the fuse box that is the 3 prong - i know that one is honda part # 31730-MAS-601
DIODE ASSY., THREE WAY (SUMITOMO)
Rules for HondaATVforums.net
If you can't figure it out,
rule 1 - drink a beer,
rule 2 - see rule 1 - rinse and repeat
rule 3 - calm down and let it sit - leave it alone
rule 4 - get on here and ask Helmut or Shadetree
rule 5 - and be nice when you ask.
rule 6 - go and
mdec950 is offline
post #2 of 13 (permalink) Old 04-25-2012, 03:42 PM Thread Starter
mdec950's Avatar
Liked: 4 times
see all pictures i posted at :
diode pictures by mdec950 - Photobucket
[/IMG]http://i159.photobucket.com/albums/t129/mdec950/diode/1wireharness.jpg[/IMG]
[/IMG]http://s159.photobucket.com/albums/t129/mdec950/diode/[/IMG]
rule 6 - go and
mdec950 is offline
post #3 of 13 (permalink) Old 04-25-2012, 04:45 PM
kentco's Avatar
Liked: 1457 times
Mdec,
Those are 10A Diodes. You can go to Radio Shack and get a 10A diode, but it won't have the nice prongs that the Honda diode has on it.
If you do get one from Radio Shack, it will need to be inserted the correct way in order for it to work. To easily figure out which way is the correct way, simply put it in one way. If it works, leave it. If it doesn't work, reverse the way you've inserted it.
kentco is offline
post #4 of 13 (permalink) Old 04-25-2012, 04:48 PM
kentco's Avatar
Liked: 1457 times
By the way, what makes you think that one of the diodes might be bad?
You can easily test them with a meter that checks for continuity.... Place the leads of the meter across the diode leads. In one direction, you should have continuity. When the leads of the meter are reversed, you should have no continuity. Simple as that.
kentco is offline
post #5 of 13 (permalink) Old 04-25-2012, 05:22 PM Thread Starter
mdec950's Avatar
Liked: 4 times
I tested them with a multimeter
no continuity either way
red to 1
black to 2 nothing
nor red to 2
black to 1 nothing
rule 6 - go and
mdec950 is offline
post #6 of 13 (permalink) Old 04-25-2012, 05:47 PM Thread Starter
mdec950's Avatar
Liked: 4 times
radio shack
ebay
manual explanation of testing
rule 6 - go and
mdec950 is offline
post #7 of 13 (permalink) Old 04-25-2012, 07:32 PM
kentco's Avatar
Liked: 1457 times
Mdec, if you have no continuity either way, then they are definately bad. Now, the question is: Why, or what damaged them? That is an important question to answer before youinstall new diodes.
The 10A Radio Shack diode that you show above should work fine. It even looks like the leads are thick enough to plug in where the Honda diodes were plugged in.
kentco is offline
post #8 of 13 (permalink) Old 04-25-2012, 10:45 PM
Liked: 1883 times
North Little Rock Honda Yamaha Dealer of Motorcycles, ATVs, Scooter Rhinos, Big Reds, Generators. Parts, Service accessories. number 7 in this fich. part number DIODE, THREE WAY
31730-MAS-601
shadetree is online now
post #9 of 13 (permalink) Old 04-25-2012, 10:47 PM
#7 is the 3-way diode in the fuse box. He's looking for the 2-way diodes that plug into the wiring harness near the gas tank.
post #10 of 13 (permalink) Old 04-25-2012, 11:07 PM
Liked: 1883 times
no others are listed for his bike ???.
