honda rancher 350 es problem - Honda ATV Forum
post #1 of 8 (permalink) Old 03-13-2012, 01:41 PM Thread Starter
digitalsoul's Avatar
alright, i have a 2001 Honda rancher 350 ES. its a great bike overall but now for some reason, it gets stuck in gear. like i will get up into 3rd or 4th for example, and then i cant up or down shift. and the only way to be able to shift is to shut off my ATV and then turn the key on and downshift into neutral then start it up again. i'm guessing its the ES, but if i'm right, which part of it? i seen there is a diagram with all of the ES components but i cant tell which part it might be messing up. any help will be appreciated, thanks
digitalsoul is offline
post #2 of 8 (permalink) Old 03-13-2012, 01:46 PM
rebelboy22jd's Avatar
Liked: 4 times
sounds like the angle sensor is going bad to me
97 300 4x4 Desert Tan - 54%, ebc clutches, oil cooler, br cam and timing chain, yoshimura exhaust, uni, 3" lift, 4" body, led light pods, snorkeled, disc brakes, 28" wide laws, hl rims, rear brake delete, removable paddle, arched lower a-arms, 1.5" rear spacers
96 300 2x4 Green - br rear end, rear basket rack, flush mount LED's, 2500# warn
91 300 4x4 Red - Next Project
91 300 4x4 Red - br rear end, 25" Vamps
85 big red 250 - another project
rebelboy22jd is offline
post #3 of 8 (permalink) Old 03-13-2012, 02:27 PM Thread Starter
can you send me a link for the correct one? or how much it would cost maybe?
post #4 of 8 (permalink) Old 03-13-2012, 08:05 PM
Liked: 4 times
Here is one.
New 2000-2003 Honda TRX 350 TRX350 Rancher ATV OE Shift Angle Sensor | eBay
post #5 of 8 (permalink) Old 03-13-2012, 08:06 PM
Liked: 4 times
and welcome to the forums
post #6 of 8 (permalink) Old 03-13-2012, 11:10 PM
Welcome to the forums. X2, more than likely, a bad angle sensor.
post #7 of 8 (permalink) Old 04-03-2012, 08:31 PM
hatvrancher's Avatar
Have seen 4 ranchers with same problem, all were a broken/ frayed wire in the plug/connector at the angle sensor. All seemed to b worse the colder it got outside. 2 were 2000, 1- 2001, and 1 2002 models. Honda does not, or did not at the time, sell repair pins and connectors like u can buy for packard connectors. I used marine connectors, from mercury marine dealer, that had heat shrink connectors, been working fine since repair. Check the harness connector and wires, good luck!
hatvrancher is offline
post #8 of 8 (permalink) Old 04-03-2012, 08:59 PM
falconblack's Avatar
Great info HatVrancher
falconblack is offline
