02-09-2012, 06:53 PM
#1 (permalink)
Member #16020
Few rancher questions ( also new rancher owner)
I purchased a 2002 rancher 350, 4x4 , this will be my second ATV , the first Honda ( I have always loved the Honda look ) I have owned. The few questions I have are ...
Where does the heater wire at the bottom of the carb plug into ? I know it does not hurt any thing to have it unplugged I just don't want all that mud getting in the connector.
And how do you go about adjusting the front breaks ?
And I'm also looking for a tails light lens for it what years can I get a lens from? From what I gather I think 2001-2003 are all the same ?
02-09-2012, 07:11 PM
#2 (permalink)
Welcome to the forums. There should be a connector in the wiring harness, near the carb for the carb heater to plug into.
The '00-'03 Rancher tail lights are all the same.
Click on the link below and download the service manual and in the maintenance chapter, it will show you how to adjust the brakes. It's easy, just remove the rubber plugs from the wheels and use a flat screwdriver to turn the adjusters. There's two adjusters to each front wheel.
2000-2003 Rancher 350 Service Manual.pdf
02-09-2012, 08:11 PM
#3 (permalink)
Member #16020
Helmet thanks , I'm sure I will have more questions , and I still can't find where that wire connects to
02-09-2012, 08:16 PM
#4 (permalink)
You're welcome. That connector should be attached to the frame under the plastic cover that you remove the access the recoil starter. You can see it in the picture below.
02-09-2012, 08:28 PM
#5 (permalink)
Member #16020
Sweet if I get a minute tomorrow I will see if I can't find it
02-09-2012, 08:34 PM
#6 (permalink)
Member #14174
Welcome dude !! I like them old ones !!!!!!
05 Green Foreman
DGL,2"SS-Lift
Plano green hunting box
11 Green Rubicon
Gscape,power steer
crappy stock tiers
Kolpin hitch
http://youtu.be/i9MhWDPUDHo
02-09-2012, 08:35 PM
#7 (permalink)
Member #11745
I think u may have to take the right side panel off to get to it
2011 rancher at
2" high lifter lift
High lifter springs
K&N and pre filter
Hmf penland pro
Viper elite 4000# winch
Kenda executioners 25-10-12 on all 4 on itp rims
02-09-2012, 08:45 PM
#8 (permalink)
Member #16020
Thank you vermhot, crazy you mean the panel that covers up the recoil starter handle ?
02-09-2012, 08:57 PM
#9 (permalink)
Member #11745
The red right side panl theres a cluster of 3 wire plugs there I'll try and get a pic of where it is tom
2011 rancher at
2" high lifter lift
High lifter springs
K&N and pre filter
Hmf penland pro
02-09-2012, 09:01 PM
#10 (permalink)
Member #4493
Welcome from the Volunteer state.
2004 Rincon, 2" lift, 27" mudlites, ITP SS212's, 710 BBK and hot cams mudbuster.
05 honda rancher carb heater, 2002 honda rancher carburetor heater plug in, 2002 honda rancher owners manual pdf, adjusting front wheels on rancher, body panels for honda rancher atv, broken carb heater wire honda rancher, honda 4 wheeler body pins, honda atv 00-03 service manual, honda carburetor heater, honda rancher carburetor heater, honda rancher loose front wheel ?, honda rancher owners manual pdf, honda rubicon carb heater wires, how to remove panels off honda rancher, how to take a 00 honda rancher carburetor off, plug in heater for honda atv, rancher questions, recoil starter for rancher 420, what does service manual for honda atv show you, what is the electrical plug on the 06 honda rancher carburetor
