03 honda rancher not firing? - Honda ATV Forum
post #1 of 9 (permalink) Old 01-05-2012, 08:49 PM Thread Starter
mudigger's Avatar
just got this bike and i cant get it to fire. dash lights come on and cant get a neutral light to come on, the gear says "--" so im thinkin this is why it wont fire. when i unplug the 22p connector the neutral light comes on but no fire. bike is definetly in neutral and rolls fine and turns over fine, any help would be much appreciated.
its te model, es.
mudigger is offline
post #2 of 9 (permalink) Old 01-05-2012, 10:53 PM
rich450es's Avatar
welcom to the forum
are all the electrical conections tight? the fuesses good and the battery fully charged?
can you shift it through all the gears manualy ?
2000 FOREMAN 450 ES-S
warn 424 sold
14% 300 basket gear reduction
2500 lb warn winch sold
29.5x10x12 swamplites on ITP C-5 wheelssold
ssatv 2in lift
superatv disk brake conversion kit sold
progresive 512 shocks
the original custom 4inch PVC storage on front rack
if you need 450 parts PM me
rich450es is offline
post #3 of 9 (permalink) Old 01-05-2012, 11:00 PM
Welcome to the forums. Might be a bad gear position switch. The service manual will show you how to test it.
post #4 of 9 (permalink) Old 01-05-2012, 11:15 PM Thread Starter
mudigger's Avatar
the battery is fully charged and all fuses are good and i checked all connectors and they have no corrosion, i will check the gear position sensor tomorrow. shifts fine manually.
mudigger is offline
post #5 of 9 (permalink) Old 01-06-2012, 01:25 PM Thread Starter
mudigger's Avatar
gear position sensor an gear switch checked out fine. What would make the ecu not want to show neutral?
mudigger is offline
post #6 of 9 (permalink) Old 01-06-2012, 02:11 PM Thread Starter
mudigger's Avatar
just found that the diode has no continuity, maybe thats whats wrong. thanks for the help guys ,great website. well its not that either, im really stumped.
mudigger is offline
post #7 of 9 (permalink) Old 01-06-2012, 03:45 PM
Find the light green/red wire going to the gear position switch and temporarily ground the wire and see if the neutral light will come on. It should come on if you're getting power to the neutral light because the light green/red wire just grounds the circuit when you're in neutral.
It's strange that the neutral light won't come on if the gear position switch is good.
post #8 of 9 (permalink) Old 01-06-2012, 05:27 PM Thread Starter
mudigger's Avatar
thanks , i tryed to ground the green/red wire allready and didnt work. well i officially solved the mystery, well not all the way but heres what i did, i noticed i didnt have 9 volts or whatever at the icm black/white wire so i ran a strait wire from the battery and wallakabing, everything works perfect, i hear a click in the ecm and the electric shift works perfect. must be a bad connection somewhere but i checked evrything i could possibly think of. so it will be ridable atleast ,thanks all.
mudigger is offline
post #9 of 9 (permalink) Old 01-06-2012, 05:32 PM
Liked: 1713 times
i would say your not getting power from your battery to your ignition switch..back to your ecm...start at the battery..and work your way to your ignition switch..then from there..back into your wiring harness.
shadetree is online now
