2011 Rancher 420 SRA clicking noise. - Honda ATV Forum
Old 09-01-2011, 11:44 AM   #1 (permalink)
charold09's Avatar
Member #12586
View charold09's Photo Gallery(0)
Brought the bike home a week ago. Im hearing a clicking/popping sound from the rear end. Did some research and saw this was a common problem but couldnt find where anyone found the solution. This bike has 7 miles on it. Seems to make the noise in reverse and 1st and 2nd gear. Havent noticed it in 3rd 4th or 5th though. Also doesnt make the noise in neutral when i push or pull on it. Im gonna check the axle nuts and lugs to eleminate that once i get home from work. Anyone have any input/ideas on this? Hate to bring it all the way back to the dealer since duck season is a week away. TIA!
charold09 is offline   Reply With Quote
Old 09-01-2011, 12:13 PM   #2 (permalink)
N.E.T.O.'s Avatar
Member #5110
View N.E.T.O.'s Photo Gallery(0)
Clicking noise solution...
Hey,
I hope this helps...
My 2007 420 SRA was doing the exact same thing. Clicking/popping noises from the rear end.
I figured the bearings were bad due to the so called defective seal on the rear end. Since I had bought it used, and had obviously been thru mud, I figured that was the issue. I bought the new side bearing and seals and fluid online and started disassembling. Wasn't a bad job, but in the dissassembly noticed that the big nut on the left side of the axle, that tightens against that tube that goes over the axle a little bit on that side, wasn't very tight. I went ahead and changed out the parts, noting that the fluid was still clean, and the seals and bearing did not look bad.
Sure enough that solved my problem, but just as an experiment I loosened that big axle nut...and the clicking came back! Tightening it went away.
Long story short, I probably could have just tightened that big axle nut on left side and would have been fine, but at least now I know that the bearings/seals/fluid is all good.
Try tightening that nut and see what happens. (Not the WHEEL nut, there is an AXLE nut on the LEFT side, on the left side of the tube that butts against the rear diff gear.
Hope this helps!
Randy
N.E.T.O. is offline   Reply With Quote
Old 09-01-2011, 12:21 PM   #3 (permalink)
charold09's Avatar
Member #12586
Thanks Randy, im gonna check it when I get home. If thats not the problem its going back to the dealer. Glad I joined this site. Tons of info here.
Old 09-01-2011, 07:26 PM   #4 (permalink)
bobs330's Avatar
Member #8144
thanks for the post, i also have an SRA 11 rancher but its not clicking or anything, my noise is from the front diff input seal squeaking but i grease it and it quits.
2011 Rancher 420 FPM
AMS Swamp fox tires
Stearns rear rack bag
Superwinch Terra 25
Moose rear bumper
Old 09-01-2011, 09:11 PM   #5 (permalink)
bluecollerhero's Avatar
Member #10506
View bluecollerhero's Photo Gallery(0)
Maybe thats whats up with mine have both yalls issues just been too lazy to do amything Bout it tbh. The squeeking when i turn is really agrivating. Im on vacay right now so ill look into it tomorrow
2011 Honda TRX420FPM
Mad Dog "tow strap" rack
26" Itp Mudlites skinny/wides
12" Itp SS312 wheels
Boss 6.5" audio tube w/ tweeters
Yutrax back rest
Dual Snorkels
Under construction:
12v acc. Mod
Viper winch
Front and rear bumpers
28" skinny laws
bluecollerhero is offline   Reply With Quote
Old 09-01-2011, 09:17 PM   #6 (permalink)
bobs330's Avatar
Member #8144
mines kind of. i called the dealer and talked to the service guy and he said whats it doing etc its not contaminating oil with mud/water and letting oil out just squeaks alittle. he said if it works just lube it, if i want bring it in and theyll look at it. ill probably take it in when riding slows down, still has 9 months of warranty left just dealer i bought it from is 50 miles away and the dealers here in town IMO have shady service depts, one charged my old boss like $165 to change oil. so i spray a lithium grease on it everynow and then or ride in water and it shuts up for a while
AMS Swamp fox tires
Superwinch Terra 25
Moose rear bumper
Old 09-01-2011, 09:24 PM   #7 (permalink)
Member #10506
Ill try that. Maybe look around for a more permanent solution. If i find one ill let u know
Yutrax back rest
Dual Snorkels
Under construction:
12v acc. Mod
Viper winch
28" skinny laws
Old 09-02-2011, 08:51 AM   #8 (permalink)
charold09's Avatar
Member #12586
Well guys I checked everything for tightness last night and everything was good and tight. Noticed that it only clicks or knocks with a load on it. Definitely sound like its come from the gear case. Going back to the dealer this morning. I'll let you guys know the out come.
Old 09-02-2011, 08:57 AM   #9 (permalink)
Member #10506
Ya might have to bring mine in if my stuff aint tight
Yutrax back rest
Dual Snorkels
Under construction:
12v acc. Mod
Viper winch
28" skinny laws
Old 09-02-2011, 08:58 AM   #10 (permalink)
bobs330's Avatar
Member #8144
im glad my rear ends not making noise. just that seal up front.
AMS Swamp fox tires
Superwinch Terra 25
Moose rear bumper
2011 honda racher 420 making clicking noise at the rearend
2011 honda rancher rear end noise
2012 honda rancher axle bearing trouble
420 honda atv rear end noise
420 rancher water in axle
bearring in 420 honda rear
honda atv 420 starter making clicking noise
honda rancher 420 making noise
honda rancher popping
honda rancher rear end cracked
rancher 420 rear end noise
rear axle bearing 07 honda rancher 420
