07 420 ignition timing. HELP - Honda ATV Forum
post #1 of 9 (permalink) Old 03-24-2011, 04:26 PM Thread Starter
79andy79's Avatar
how do i set the ignition timing? any help is much appreciated. thanks
79andy79 is offline
post #2 of 9 (permalink) Old 03-24-2011, 04:31 PM
Liked: 316 times
Pm me your address I'll send you the service manual
TRX2fiveO is offline
post #3 of 9 (permalink) Old 03-24-2011, 04:34 PM
Welcome to the forums. There's no way to adjust the ignition timing as the timing advance is built into the function of the CDI. You can check the ignition timing, but you can't adjust it.
post #4 of 9 (permalink) Old 03-24-2011, 04:35 PM
You can find a link to the service manual in the manuals/schematics section of this forum.
post #5 of 9 (permalink) Old 03-24-2011, 04:38 PM Thread Starter
79andy79's Avatar
see my drain plug threads broke off in my case. i took my engine out and the case ends off each side to remove the drain plug threads. so gears kept sliding out. i thought i had everything back the way it was but it wouldnt start. i got spark fuel air and compression. what am i doing wrong?
79andy79 is offline
post #6 of 9 (permalink) Old 03-24-2011, 08:59 PM
Liked: 1883 times
you some how didn't get your timming set right..by this..i mean you didn't set your crank..cam..valves for the bike to fire at the right time, this is where your timming chain..valves and crank come into play, if you don't get all of these set right..not only will you not get the motor to run..but you risk doing alot of motor damage to your engine..such as valves getting smacked by your piston..destroying your piston and valves.
shadetree is online now
post #7 of 9 (permalink) Old 03-25-2011, 04:03 PM Thread Starter
79andy79's Avatar
crank and cam wasnt ever out. it was trans gears that was sliding out. and it isnt a chain motor as far as i know. its gear to gear.
79andy79 is offline
post #8 of 9 (permalink) Old 03-25-2011, 04:27 PM
Actually, it's not gear to gear, it does have a timing chain. The timing chain and cam are behind the front crankcase cover on the 420 Rancher.
post #9 of 9 (permalink) Old 03-26-2011, 06:27 AM Thread Starter
79andy79's Avatar
well i didnt have that off so thats shouldnt be out
79andy79 is offline
