09-17-2009, 07:08 AM
#11 (permalink)
Member #417
When I mentioned tight valves i was referring to improper adjustment, they won't tighten themselves, how ever they will loosen a bit. getting louder when warm the oil loosen a bit giving the effect of slightly louder ticking but it doesn't assume they are correct... feeler gauges will determine that
Originally Posted by Pain
Is it fair to assume that most of the time under most normal conditions that the valves will loosen, rather than tighten over time?
And, is it also true that if the ticking doesn't get louder as the engine becomes warmer, then chances are everything is OK?
I heard ticking on just about everything I've ever owned, but it's never gotten noticably louder as the engine warmed up.
MOOSE
1991 TRX 250X
12:1 wiesco piston @ 60 over
stage 1 cam,
Vesra connecting rod
High performance coil
jet kit, 400EX carb, K&N filter,
FMF power Core 4 full exhaust,Tusk nerfbars.
Coming soon Ported and polished headECT. ECT.
09-17-2009, 06:33 PM
#12 (permalink)
Member #126
Agree!!!!!!!!!!!!!!!!!!!!!!!!^^^^^^^^^^^^^^^
09-17-2009, 06:54 PM
#13 (permalink)
Member #199
Ok thanks every one there getting adjusted soon
09-17-2009, 07:02 PM
#14 (permalink)
Member #199
How hard is it do adjust them myself and does it affect it performance wise.
09-17-2009, 07:16 PM
#15 (permalink)
Member #126
Easy. DO you have a SERVICE MANUAL? Are you mechanically inclined?
09-17-2009, 07:17 PM
#16 (permalink)
Member #618
It is one of the more simple things to do. One of these guys will post instructions on how to do it. You will need a feeler gauge and some shims probably.
It will be like a new machine when it's done.
I don't want to arrive at the Pearly Gates in a well preserved body... I want to slide in sideways screaming "NOW THAT WAS A F'ING RIDE"
09-17-2009, 08:11 PM
#17 (permalink)
Member #417
I elect SABER!!!He's your guy
MOOSE
1991 TRX 250X
stage 1 cam,
09-18-2009, 10:24 AM
#18 (permalink)
Member #426
X2
I will need to do mine soon. I'll probably bring mine in though as to not cause any issues with my 4 year warranty. Plus the service manager is a good friend of mine.
Tim
2007 Honda TRX 400EX
09-18-2009, 07:17 PM
#19 (permalink)
Member #126
X3  SABER6
09-18-2009, 07:22 PM
#20 (permalink)
Member #193
Done solved.
BOOB man - "Brotherhood of Oil Burners" Local 715
Sometimes I wonder,.."Why is that Frisbee getting bigger,..? then it hits me,...
» Site Navigation |
» Honda Forums
