Old 10-25-2010, 07:50 PM   #1 (permalink)
scotty8882003's Avatar
Member #6192
View scotty8882003's Photo Gallery(0)
wont shift into neutral
We unloaded the wheeler from the truck it went into nuetral fine and put it into gear while we took the gas tank off and fixed it. The electric start is bypassed so we can kick start it. I was wondering if the electric start not working has something to with it not going into neutral? does the key have to be on for the wheeler to go into nuetral? like i said it went into neutral fine a week ago when we took it out of the truck after i bought it and now it seems to not want to go into neutral
scotty8882003 is offline   Reply With Quote
Old 10-25-2010, 08:09 PM   #2 (permalink)
94300ex's Avatar
Member #4561
View 94300ex's Photo Gallery(0)
welcome to the forums. what kind of bike is it? the starter shouldn't have anything to do with it not shifting into neutral
seven tools that can fix anything: duck tape, electricians tape, vise-gripes, WD-40, JB weld, a big hammer and a crescent wench.
94300ex is offline   Reply With Quote
Old 10-25-2010, 08:14 PM   #3 (permalink)
Welcome to the forums. I agree with 94300ex. When you say it won't go into neutral, do you mean it won't go into neutral or do you just mean the neutral light doesn't come on?
Old 10-25-2010, 08:18 PM   #4 (permalink)
Member #6192
its a 250 fourtrax and the battery isnt even hooked up so the neutral light wldnt come on, would it? I guess i never looked to see if it had come on before.
Old 10-25-2010, 08:19 PM   #5 (permalink)
Member #6192
it just wont go into neutral
Old 10-25-2010, 08:35 PM   #6 (permalink)
You could try to adjust the clutch free play. If that doesn't help, you have a problem with the shift linkage or the transmission, itself and you will have to tear it down to find the problem.
To adjust the clutch free play, find the adjusting screw on the right side of the engine. Loosen the locknut and slowly turn the adjusting screw counterclockwise until you feel resistance. Now, turn the adjusting screw clockwise 1/4 turn. Lastly, hold the adjusting screw while tightening the lock nut.
I really doubt the clutch free play is the problem, but I would try it anyway, before tearing into the engine.
Old 10-25-2010, 08:36 PM   #7 (permalink)
No, if the battery isn't hooked up the neutral light won't come on, unless the engine is running.
2007 honda recon neutral light won't come on
four wheeler is off and wont go into neutral
four wheeler wont go in neutral
four wheeler wont go into neutral
honda 3 wheeler wont go into gear
honda 4 wheeler wont go into neutral
honda foreman wont shift into neutral
honda four track wont go into nutral or start
honda four wheeler wont go in neutral
honda fourtrax won't go into neutral
i have a honda 4?4 four wheller and it wont go into gear
why won't my honda four wheeler go into neutral
