'98 fourtrax 300 carb trouble - Honda ATV Forum
post #1 of 13 (permalink) Old 07-17-2010, 10:40 AM Thread Starter
kathomps's Avatar
Question '98 fourtrax 300 carb trouble
New to the forum here and have a problem. My 98 fourtrax hadnt been ridden in a month or more and after i charged the battery back up, the thing would not start. So, i take off the carb, take it all a part, blow all the fuel and vaccum lines clear, cleaned up the float and needle valve. The needle valve was the problem for the starting. Now it starts fine but i am forced to choke it in order for it to keep running under idle. Under about half throttle, the engine hesitates some, but under full throttle there is not problem whatsoever. I have a feeling I messed up something with the rubber piece that connects to the top of the cylindrical plastic vaccum piece in the center of the carb. I am stumped because Ive taken off the carb 3 times now and cleaned it out and it still has problems. Any help is appreciated. Thanks.
kathomps is offline
post #2 of 13 (permalink) Old 07-17-2010, 12:00 PM
Welcome to the forums. I would say that there is still some debris in the idle circuit. Did you clean out the tiny passageways in the carb body?
post #3 of 13 (permalink) Old 07-17-2010, 12:29 PM Thread Starter
kathomps's Avatar
I believe i got all the passageways. I took the whole thing completely apart twice now and blew out all the passages i could find. It seems like each time I took it apart and back together, the engine behaved a little differently each time. Kind of like i solved one problem but there still is another one to fix.
kathomps is offline
post #4 of 13 (permalink) Old 07-17-2010, 12:44 PM
It's real easy to miss something when cleaning a carb, just a tiny piece of debris will cause you problems. You may have to remove all the rubber pieces from the carb body and soak it in some carb cleaner. It doubt if you damaged the rubber vacuum piston in the top of the carb unless you tore it, but that would be easy to see.
post #5 of 13 (permalink) Old 07-17-2010, 12:50 PM Thread Starter
kathomps's Avatar
Alright thanks Ill try that. Ill let u know if that solves it.
kathomps is offline
post #6 of 13 (permalink) Old 07-19-2010, 08:56 PM Thread Starter
kathomps's Avatar
Well, tried the carb cleaner today and no luck. Im gonna try it one last time tomorrow and then I might just get a rebuild kit from somewhere. Does anyone have info on where and how much a rebuild kit might be?
kathomps is offline
post #7 of 13 (permalink) Old 07-19-2010, 09:19 PM
You can get them on Ebay for $18.95.
93-00 Honda TRX 300 Fourtrax Shindy Carburetor Carb Kit: eBay Motors (item 280513158836 end time Jul-26-10 13:09:44 PDT)
post #8 of 13 (permalink) Old 07-23-2010, 09:59 AM
mlauk's Avatar
I just went through this with my 99 trx 300. It turned out the idle circuit and another circuit was plugged up solid (it had been sitting for 2-3 years when I bought it).
I used a Clymer service manual which had step by step instructions with great pictures and would suggest you get one just so you don't miss anything.
mlauk is offline
post #9 of 13 (permalink) Old 07-23-2010, 12:04 PM
Liked: 1724 times
your idle jet is stoped up..it doesn't take much to mess up the jet..also..like helmut said..make sure you didn't tear the top gasket..if and when you get it right..a simple little inline fuel filter between your gas tank and carb will save you a headace down the road.
shadetree is online now
post #10 of 13 (permalink) Old 07-24-2010, 07:41 AM
wheeler's Avatar
Liked: 81 times
Something similar happened to me when I had my carb apart.
It turned out ( which I didn't know till I read the manual ) but when you reinstall the top on the carb, you have to align the tab on the vacuum cup and tab on the top of the carb. My bike acted all up. I didn't realize I had the top on wrong. Double check you have aligned the tabs up.
Once I corrected that it was all good.
wheeler is offline
