Oil What Kind to use????????? - Page 4 - Honda ATV Forum
Old 08-02-2011, 09:03 PM   #31 (permalink)
JaneFonda's Avatar
Member #11949
View JaneFonda's Photo Gallery(0)
Here is another question, how much do the 86 250 engine hold ??
JaneFonda is offline   Reply With Quote
Old 08-03-2011, 02:05 AM   #32 (permalink)
Welcome to the forums. If you're talking about the '86 Fourtrax 250 utility model, it holds 2.2 quarts.
Old 03-22-2012, 09:00 AM   #33 (permalink)
CRapflinger's Avatar
Member #16112
View CRapflinger's Photo Gallery(0)
I've got a 2012 Rancher AT. the manual lists 10w40 as the highest range on the oil. is it ok to use the rotella triple 15w40 in this quad? seems to be pretty difficult to find the 5w anywhere local. also, i'm in east TN so, temperate weather climate.
CRapflinger is offline   Reply With Quote
Old 03-22-2012, 05:16 PM   #34 (permalink)
Ballast's Avatar
Member #8124
View Ballast's Photo Gallery(0)
Liked: 31 times
The Rotella 15W-40 is regular oil, the 5W-40 is the Rotella T6 synthetic which I highly recommend, it's at walmart and others about $23 for gallon jug - it's dark blue
4 HONDAS 4 ME
85 TRX125.... sadly sold
Ballast is offline   Reply With Quote
Old 03-22-2012, 06:34 PM   #35 (permalink)
Hazcat's Avatar
Member #17140
View Hazcat's Photo Gallery(0)
I'm not a synthetic oil snob like some people at the same time synthetics are usually a "thinner" viscosity oil. Using a 15w-40 oil is a "thicker" oil and you may see upper engine wear using it versus 5W oils. The majority of engine wear occurs during start up. The thinner oils reach the top of the engine sooner therefore securing good lubrication quicker on start up even in temperate climates. Once they are warmed up then it's no longer an issue. I highly recommend the thinner regular oils (5W) or a synthetic. If for some reason you just have to use 15W-40 then I would recommend an oil heater prior to starting your bike. You can use a search engine and find easily....just type in atv oil heater.
Hazcat is offline   Reply With Quote
Old 03-23-2012, 11:33 AM   #36 (permalink)
Member #16112
well, i was weary of the 15w-40 already because it's above the recomended range in the manual anyway (stops at 10w-40), i'm not sure why i didn't look at the synthetic but it looks to be twice the price at walmart than the non synthetic. though they also show a 10w-30 in the rotela tripple online, but no price or store availability
Old 06-05-2012, 04:42 PM   #37 (permalink)
ziebartowner's Avatar
Member #19486
View ziebartowner's Photo Gallery(0)
I may be able to offer some assistance in the oil quesiton as I used to develop specialized racing synthetic oils however not for wet clutch use.
ziebartowner is offline   Reply With Quote
Old 11-08-2014, 10:03 PM   #38 (permalink)
D.ROSE.PHMS's Avatar
Member #42893
View D.ROSE.PHMS's Photo Gallery(0)
Originally Posted by my5sons View Post
I use Amsoil 4-stroke Full Synthetic 0w-40. It works to substitute it for 5w-30, 5w-40 and 10w-40 oil. Because it is synthetic, it offers protection down to -30 degrees F during the winter. The best (in my opinion) all season Oil you can buy.
just my thought I have a2013 foreman I have used gn4 10 40wt but have switched to vavoline 10 40 for 4 strokes had as many miles as gn4 seems the valvolene came out pretty clean plus its about 1.25 qt cheaper at least here in Pittsburgh any way if you decide to go synthetic remember don't mix brands and don't go back and forth stay with one cause synthetic has a high amt of detergents which causes foam and in time will cause slippage if it dnt come with synthetic don't waste money go with a good brand sae oil for wet clutches hope this helps
D.ROSE.PHMS is offline   Reply With Quote
Old 11-10-2014, 06:49 AM   #39 (permalink)
Roadking's Avatar
Member #39072
View Roadking's Photo Gallery(0)
Liked: 22 times
Download your service manual and it will tell you what weight oil to use under your driving conditions. Personally I reccomend using the GN4 for break in, then switch over to a full synthetic such as Mobil1. Esp if you are in the south and ride during the hotter weather.
But whatever you do make SURE the oil you choose has the right JASO ratings for motorcycles and wet clutches.
Wow 33 thousand views !!! Thats gotta be a record
02 Electraglide Classic
03 100 Anniv. Heritage
88 Trx 300 2x4
Roadking is offline   Reply With Quote
Old 11-10-2014, 11:26 AM   #40 (permalink)
Casey6404's Avatar
Member #28765
View Casey6404's Photo Gallery(0)
Shell Rotella T6, awesome oil. Walmart has for around $21 a gallon and they do a $5 rebate several times a year. I run it in all my stuff.
2010 Rancher 420 TM
Superwinch LT2000
26" Duro Power Grip Radials
ITP SS212 Wheels
Kolpin Overfenders
New Plastics (Old School 2007 Blue)
ODI Rogue Lock On Grips
2001 Recon
Casey6404 is offline   Reply With Quote
4 wheeler oil type
atv oil type
best oil for honda atv
do you have to use honda oil in a honda atv
honda 4wheeler oil to use
honda atv oil
honda atv oil type
jaso ma certified oils
oil for honda 4 wheeler
quad oil type
shell rotella t-6 in atv
what oil to use in honda atv
