03-17-2010, 05:28 PM
#1 (permalink)
Member #2428
250 recon rear end...
can anyone tell me how to get the pinion out of the the gear case of a 250 recon?
I'm trying to salvage this rear end if I can, but cant seem to get the pinion out.
Thanks. Tim B.
03-17-2010, 05:36 PM
#2 (permalink)
There's a big nut that screws into the end of the differential, where the drive shaft fits. This nut has threads on the outside of the nut that threads into the diff. The inside is hex shaped. It takes a special tool to remove it.
03-17-2010, 05:42 PM
#3 (permalink)
if you don't have the tool to remove the hex nut..you can try something i do..if you can get your hands on a sqaure piece of tubing..i can't remember the size..1 1/2 or 2 inches..it fits down inside the nut at the right angle, with a pipe wrench..you can take the hex nut out.it does work..it's just finding the right size of tubing that fits. maybe you can get a measurement across the nut..and see what size will work..sorry i can't remember the size..but..it sure beats paying a boat load of cash just for this tool..when you may only use it once in your life..lol.
03-17-2010, 05:48 PM
#4 (permalink)
You can make the tool if you really want to. I made one for me and I made one for one of my buddies. It's easy, but you have to find a large fitting of some kind with an outer hex shape that is the same size as the inside of the nut. Then just cut it off and weld it to the end of an impact socket. Works great. I can't tell you where to get the fitting, though. I just happened to already have a bunch of fittings and already had some that were perfect. And by the way, it has to be made of steel, so you can weld it.
03-17-2010, 08:10 PM
#5 (permalink)
Member #1088
The welding thing is a given helmut.
Billy
1991 Trx250X Custom exhaust,K&N jetted,widened 7.5 inches in the back and 8 inches in the frontWarrior rear shock and z400 front shocks with custom brackets.Race cut fenders.+3 swingarm.Way more to come.
Building things makes me happy.
03-17-2010, 08:15 PM
#6 (permalink)
Some of the fittings are brass. I didn't won't someone to go to the trouble of buying one and not thinking about it and then getting home and realizing that they can't weld it. But if they're a welder, then they wouldn't do that I suppose. LOL.
03-17-2010, 08:16 PM
#7 (permalink)
Member #1088
We'd hope not anyways or they had there head in the wrong place.LOL
Billy
2000 honda recon 250 rear end, 2004 honda recon rear end, 250 recon rear end diagram, cheap rear end for honda 250 recon, diagram for a 2000 honda recon rear end, fourtrax 250 rear end, grease bearing a 1989 honda recon 250, honda 250 recon (2003) rear end dope weight, honda recon 250 rear axle, honda recon 250 rear end, honda recon axle remove, honda recon rear axle, honda recon rear axle diagram, honda recon rear differential, honda recon rear end, how to take apart a rear end on a 2000 honda recon, rear end for honda recon 1999, removing axle nut 250 honda recon atv, used honda recon rear end, used rear end for 250 honda recon
