rocker adjustment - Honda ATV Forum
post #1 of 6 (permalink) Old 01-20-2012, 07:12 PM Thread Starter
trx 350's Avatar
rocker adjustment
How doi adjust the rockers on my bike? They are making noise any help would be great
1986 Honda TRX 350 FOURTRAX
24"x9-11 ITP Mud Lites AT
UNI Air Filter
Smitty Bilt 3k Winch
Redone Plastics
Silver Star Lighting
trx 350 is offline
post #2 of 6 (permalink) Old 01-20-2012, 07:21 PM
Snotrod's Avatar
Download the service manual from this site. It will explain the process in detail. It will also give the specs for valve lash. The hardest part is keeping the tappet set where you want it while tightening the jam nut.
Snotrod is offline
post #3 of 6 (permalink) Old 01-20-2012, 07:36 PM
X2, either download the service manual or go to this thread and read post #4.
Honda Valve Adjustment Procedures (Utility Models)
post #4 of 6 (permalink) Old 01-20-2012, 07:36 PM
And if you want to download the service manual, here's the link:
1986-1989 Fourtrax-Foreman 350.pdf
post #5 of 6 (permalink) Old 01-20-2012, 10:07 PM
Liked: 1731 times
make sure your adjusting the valves with a cold engine !!!..and make sure your adjusting them with the piston on TDC ( top dead center ) on the compression stroke !!..if you do it right ?..then you should not hear the valves..and even if you do it right..and you still hear tapping or slapping ?..this is your cam chain.
post #6 of 6 (permalink) Old 01-25-2012, 08:12 AM
speerfamily's Avatar
And if it IS the cam chain, get it replaced. Mine was making noise and I ignored it, then it slipped a tooth and bent both my valves. When you check the chain, it should be good and snug...
94 Fourtrax 4x4 w/2 inch lift & winch
speerfamily is offline
