How do I test the Rectifier/Regulaor on a 1994 Honda 300 Fourtrax!!!! - Honda ATV Forum
Old 10-05-2011, 08:48 PM   #1 (permalink)
gln97058's Avatar
Member #13298
View gln97058's Photo Gallery(0)
Good evening guys I could use your help again I want to test the Rectifier/Regulator on my 1994 Honda 300 Fourtrax 4x4. I went to the Clymer book to get instructions but it only explains how to test a 93 or earlier the test prodecure it talks about is a three wire which is red, black and green but on the 94 I only have a two wire connection and that is I just have a red and green wire so I can't test it lit lt says to test it in the book becase I don't have a black wire coming out of the regulator. I checked with the switch off across the red and green and I have battery voltage about 12.5 volts so what else do I need to do to make sure I don't have a bad recitifier/regulator I have a new CDI coming and I don't want to put it in and have a bad regulator blow it out so I need to make sure the regulator is good. Thanks in advance guys you have been alot of help with this bike and I have learned alot. Gary
gln97058 is offline   Reply With Quote
Old 10-05-2011, 09:10 PM   #2 (permalink)
Did you try the '88-'94 Honda factory service manual that you can download from the manuals/schematics section of the forums? I think it has a few tests for the regulator/rectifier. I always just start the engine and measure the voltage at the battery. If it's charging properly, the voltage should increase as you rev the engine. It should show about 13-15 volts.
Old 10-05-2011, 09:30 PM   #3 (permalink)
gln97058's Avatar
Member #13298
Helmut it says I need a password to open that manual so I can download it? Where do I get the password?
Old 10-05-2011, 09:41 PM   #4 (permalink)
The password is Hondaatvforums.net.
300 fourtrax regulator test
check rectifier on 1994 honda 300 fourtraxx
forum how to test big red rectifier
honda 300 voltage regulator for sale fourtrax
honda fourtrax 300 voltage regulator
how to test a rectifier on honda big red 300
how to test atv rectifier
how to test rectifier on atv
rectified regulator on honda four trax
rectifier for a 1992 honda fourtrax four wheeler 300
test honda 300 fourtrax voltage regulator
voltage reg on honda 300 fourtrax
