1998 honda fourtrax 300 4x4 neutral light wont come on - Honda ATV Forum
post #1 of 18 (permalink) Old 07-07-2011, 12:54 PM Thread Starter
Mohillmudder's Avatar
I have a 1998 honda fourtrax 300 4x4. I go an put it in neutral an the neutral light that is by my key wont come on an i cant use the eletric start. I need to no how to fix it asap. thanks
Mohillmudder is offline
post #2 of 18 (permalink) Old 07-07-2011, 01:04 PM
Liked: 54 times
Welcome to the forums...Free downloadable manuals in the Schematics/Manual help section on the Technical discussions board...Check the wires coming off the neutral switch for corrosion,breaks,bare wires,unplugged ,also check the bulb itself by unplugging the neutral light wires,and hooking them to a small 9v battery...
Deeperinthabush is offline
post #3 of 18 (permalink) Old 07-07-2011, 01:16 PM
Welcome to the forums. Like Deep said, check the wire where it plugs into the neutral switch. It could be unplugged or sometimes it can have a bad connection. Also, check your fuses.
post #4 of 18 (permalink) Old 07-07-2011, 01:17 PM Thread Starter
would the bulb bein out make it not start with the push botton start?
post #5 of 18 (permalink) Old 07-07-2011, 01:22 PM
Liked: 54 times
You can check the starter by jumping a screwdriver across both large terminals on the solenoid to see if it actually works...If it does,then I'd guess that you have a neutral switch,or wiring issue...Make certain the atv is in neutral before doing any of this..
post #6 of 18 (permalink) Old 07-07-2011, 02:02 PM
The neutral light is supposed to be on before the electric start will work, but if it's just a blown bulb, it will still work, because the neutral light bulb is in a parallel circuit. Do what Deep suggested, above, and if the starter works, check your fuses.
post #7 of 18 (permalink) Old 07-07-2011, 02:07 PM Thread Starter
ok well i went out there an put screw diver on the positve of the starter an the postive of the battery. it tried to start but didnt. but i can push start it an it starts right up, i truely dont no whats wrong with it. a buddy says its probly the wirein harnass. help
post #8 of 18 (permalink) Old 07-07-2011, 02:08 PM Thread Starter
i checked the fuses an they werent blown. but the light is still not on an when i hit the elertic start button it wont do anythin.
post #9 of 18 (permalink) Old 07-07-2011, 02:11 PM
Have you checked to see if the wire was unplugged from the neutral switch?
post #10 of 18 (permalink) Old 07-07-2011, 02:24 PM
Liked: 54 times
There's a starting solenoid under the seat that the battery is attached to by a big battery cable,jump IT with the screwdriver to see if it will turn over,or start...Try this...
