1986 TRX 350 Decompression lever. - Honda ATV Forum
post #1 of 9 (permalink) Old 06-23-2011, 05:20 PM Thread Starter
supergee19's Avatar
HEy guys long time no chat! anyways, i got my bike rebuilt but i didn't change the decompression lever cable or the seal and well i got a major leak there, but what i was wondering if if i need to change that cable or not....I think i do because it is as tight as it will go, but as my bike is running that lever is moving with every RPM, and it sounds like an exhaust leak, but my exhaust is completely sealed up. so is that lever supposed to move like that or should it just be once in a while, i mean it ticks so much its annoying, i didn't notice it when i first put the motor in over the leaky exhaust but it seems like its loudd, so is it supposed to be like that or what? it wont be that expensive to replace it is but if i don't have to i wont, because funds are tight, so what i am asking is, is this noise normal? any input would be great!
supergee19 is offline
post #2 of 9 (permalink) Old 06-23-2011, 06:43 PM
It shouldn't be moving at all. Sounds like you've got the cable adjusted too tight. The only time the cable should be pulling on the lever is when you're kicking the kick starter.
post #3 of 9 (permalink) Old 06-23-2011, 07:38 PM Thread Starter
supergee19's Avatar
could that be why my bike will not idle after it warmed up?....it works fine while driving but as soon as i let off the gas it wants to die, i have to hold the brakes and keep on the gas to keep it running when im stopped. guess its time for a new cable and lever because the guy i got the motor from bent the hell out of that so i couldnt remove it when i took the top end apart.
post #4 of 9 (permalink) Old 06-23-2011, 08:07 PM
Yeah, that could be the reason it won't idle. When that lever is pulled, it holds open the exhaust valve a little, so you don't have as much compression. This makes it easier to kick start, but the cable is supposed to release the lever as soon as the kick starter returns. Low compression caused by the decompressor lever being pulled all the time could definitely cause it to not idle.
post #5 of 9 (permalink) Old 06-23-2011, 08:17 PM
Liked: 54 times
I'm pretty sure that you should be able to pry that bracket back out a touch,and adjust the cable out a turn,or two,,,,
Deeperinthabush is offline
post #6 of 9 (permalink) Old 06-23-2011, 08:21 PM
When you adjust the cable, you should have about 1/16 to 1/8 inch of play at the lever before the cable starts pulling the lever. By the way, you have to adjust the cable with the piston on TDC on the compression stroke, just like when you're adjusting the valve clearance.
post #7 of 9 (permalink) Old 06-24-2011, 03:32 AM Thread Starter
supergee19's Avatar
ok thats no biggie then, time my bike up again align all the marks like i did when i put the head back together, and as for prying that lever apart, i tried that when i was taking it apart. The guy mangled it so that why i just left it alone. but i still have the parts to my old motor so ill just get this lever out and see what my other one is like. thanks for the input guys, ill gett he parts today and fix er tomorrow and let ya know how it goes! thanks again!
post #8 of 9 (permalink) Old 06-26-2011, 05:21 PM
trx 350's Avatar
I think I may have an issue with my cable as well, where is it located? And the adjustment procedure?
1986 Honda TRX 350 FOURTRAX
24"x9-11 ITP Mud Lites AT
UNI Air Filter
Smitty Bilt 3k Winch
Redone Plastics
Silver Star Lighting
trx 350 is offline
post #9 of 9 (permalink) Old 06-26-2011, 05:31 PM
