06-03-2011, 08:31 PM
#1 (permalink)
Member #10817
pedal shifter
can i shift manualy on a 350 fourtrax electric shift
06-03-2011, 08:38 PM
#2 (permalink)
Welcome to the forums. They have an emergency shifter that can be used to shift manually in case the electric shift quits working, but it's only to shift into a gear to get you home or wherever you need to go. You have to use your hand to shift and it's not meant to shift while you're moving.
06-03-2011, 10:31 PM
#3 (permalink)
Welcome to the forums,and No..
06-04-2011, 06:39 PM
#4 (permalink)
Member #10292
cant you switch into a manual shift? with the right parts.
06-04-2011, 06:54 PM
#5 (permalink)
You could with all the right parts. Even the gears are made different on the electric shift models. The gears on the electric shift models have a different number of engagement "dogs" on the back of the gears and it may or may not hold up if you don't change those gears. On the Foreman 500, Honda tried to use the same gears on the foot shift model that they used on the electric shift models and they had a lot of first gear problems with the some of the earlier models. The engagement dogs would get worn and rounded off. Since it didn't hold up on some of the 500s, it might not hold up on the 350. They updated the 500 Foreman gears and fixed the problem. The updated gear for the 500 Foreman is shown below.
06-09-2011, 09:36 AM
#6 (permalink)
Member #8565
Hi Helmut, I read your post about the early 500's first gear problem. I bought a used one, 05 500 foreman S 4X4 It only had 490 miles on it. But it seems to shift fine for now. If someday I have first gear problems the updated gear can be installed? Is that the only thing that is in the updated kit? Or is there more to be replaced to make it work.
Thanks
Randy
06-09-2011, 01:49 PM
#7 (permalink)
Thanks
Randy
No, the updated gears come as a set, so that's all you will need.
06-09-2011, 05:13 PM
#8 (permalink)
Member #8673
welcome to the forums from TN...
 Chefsimms...1985 FourTrax 250
"The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government."
- Thomas Jefferson
4 wheeler hand shifter, four wheeler hand shifter, four wheeler shifter, hand shifter for 4 wheeler, honda 4 wheeler gear shifter, honda 4 wheeler shifter, honda emergency shifter for honda fourwheeler, honda foreman hand shifter, honda four wheeler hand shifter, how to shift a honda quad with pedal shifter, how to unlockelectric shift 4 wheeler gears, how to upgrade a pedal shift four wheeler
