honda fourtrax 300 fw 1997 - Honda ATV Forum
Old 04-04-2011, 09:33 AM   #1 (permalink)
Henry Anderson's Avatar
Member #8111
View Henry Anderson's Photo Gallery(0)
its it normal for it to struggle to speed up in 5th gear, it just takes it a while to reach full speed on a paved road.
1997 Green Honda Fourtrax 300fw
-UNI filter
-crappy tires
In the future:
-424 locker
-front disk breaks
-ITP mudlights
-12in wheels (black)
Henry Anderson is offline   Reply With Quote
Old 04-04-2011, 01:54 PM   #2 (permalink)
Liked: 1528 times
nope..it's not..sooooooooo..your next question is gonna be..what is causing mine to go slow then ...right ?..lol..could be a few things..clutch slipping..bad gas ( doubtful though )..a carb problem from the sounds of it.
Old 04-04-2011, 07:59 PM   #3 (permalink)
Member #8111
what part of the carb should i change to make more power?
-UNI filter
-crappy tires
In the future:
-424 locker
-front disk breaks
-ITP mudlights
Old 04-04-2011, 09:13 PM   #4 (permalink)
Fourtrax Mafia's Avatar
Member #7427
View Fourtrax Mafia's Photo Gallery(0)
gonna have to pull the whole carb out!
Fourtrax Mafia is offline   Reply With Quote
Old 04-04-2011, 10:46 PM   #5 (permalink)
Member #8111
OK that's easy enough, done it twice already. then what? do i need to adjust something, clean something (cause iv done that already twice)??? tell me idk what to do.
-UNI filter
-crappy tires
In the future:
-424 locker
-front disk breaks
-ITP mudlights
Old 04-04-2011, 11:02 PM   #6 (permalink)
Liked: 1528 times
you may do it a million times !..lol..as many times it takes until you get your bike running like it should.
Old 04-05-2011, 08:38 AM   #7 (permalink)
Member #8111
so adjusting the fuel/air screw wouldnt do anything?
-UNI filter
-crappy tires
In the future:
-424 locker
-front disk breaks
-ITP mudlights
Old 04-05-2011, 11:09 AM   #8 (permalink)
Liked: 1528 times
i'm sure you read my how to clean a carb..to answer your question..yes..it will effect your motor's carb..and how your bike runs..set your fuel/air screw out 2 1/2 turns from a lightly seated, it should run good then..if not..then we'll take it from there.
Old 04-05-2011, 11:18 AM   #9 (permalink)
Liked: 1528 times
try doing this..see if it helps..on the top of the carb..remove the 4 screws..remove the spring..remove the diaphram..pull the main plunger out..with a philips screw driver..reach down inside the plunger..turn the plastic main jet needls hold down counter clockwise..this piece comes out...and it holds your main needle jet in...carefully take the main jet needle out..as you will see..it has a c-clip on it ?..some..if not most of these have a tiny tiny washer ..don't loose it !, look and see where your c-clip is cliped on the main jet needle ?..there are 5 grooves on the needle..stock setting is in the 3rd groove down from the top..better known as the middle groove..put the clip there..slide the washer back on from the bottom..where it rest under the c-clip..then set the needle back down inside the plunger..put your plastic hold down back down inside the plunger..about half a turn clockwise..until it locks in place..put it back in the carb..diaphram..spring..then top...see how it runs ?.
Old 04-05-2011, 06:24 PM   #10 (permalink)
lsupride2278's Avatar
Member #9539
View lsupride2278's Photo Gallery(0)
Do you have upgraded wheels and tires? Larger tires cause the 300's to struggle in high gear, at least in my own experience
lsupride2278 is offline   Reply With Quote
1997 honda fortrex 300 atv for sale
1997 honda fortrex 300 fw atv for sale in alberta
1997 honda fourtrax 300
1997 honda fourtrax 300 how to
1997 honda fourtrax forum
97 honda fourtrax 300 how to carb
97 honda fourtrax carb settings
cleaning 97 honda fourtrax carburator
honda 300 fourtrax carb adjustment
honda fourtrax specs 1997
pulling clutches on a 97 fourtrax forum
