Old 02-09-2012, 03:37 PM   #251 (permalink)
Logan400ex's Avatar
Member #16016
View Logan400ex's Photo Gallery(0)
that thing looks bad!!
2001 trx 400ex
*full pro circuit t-4 exhaust
*DG nerf bars
*DG front bumper
*Maxxis Razr tires
*ITP ss rims
Logan400ex is offline   Reply With Quote
Old 02-10-2012, 07:34 PM   #252 (permalink)
Reece616's Avatar
Member #3038
View Reece616's Photo Gallery(0)
I got a bit done today.
I got the airbox on and setup (just have to oil the filter first.)
I got the oil system and exhaust header on.
I was planning on putting a larger oil cooler (from a rancher 400 (it's double the size of the stock 400ex)) but that didn't work out well, due to mounting problems and the oil lines. I didn't feel like holding up progress for it, especially since my motor is stock and doesn't really need any extra cooling.
The steering stem is in, but I haven't put the lower nut on yet, just because of the way it's off the wheels. I set up the bars as well, but I can't put the start switch on because the the bars are too fat because of the paint (it's extra thick.)
So I think i'm gonna clean off the paint a bit there to try to make it work.
Also, i didn't put the master cylinder on yet... (clearly haha)
The first pic shows my pathetic attempt at polishing the throttle cover.
Last pic shows a mock-up of the rear wheel. I wanted to see how badass the black wheel with orange hub looked. It is in fact very badass!
400ex Winter Overhaul-bars01.jpg   400ex Winter Overhaul-bars02.jpg   400ex Winter Overhaul-bars03.jpg   400ex Winter Overhaul-bars04.jpg   400ex Winter Overhaul-rearwheel.jpg
2006 TRX400ex
AC Nerfs - Swingarm Skid + Honda Racing Skid - Protaper Contour Bars - Rox 2" Riser - CBR Clutch Perch - Oury Grips - HT Moto Seat Cover - Custom Poly Case Saver - TRX450R Front Shocks - XR250R CDI - YFZ 450 Dual Piston Front Calipers - ITP T9 Baja Rear + GBC X-Rex - CanAm DS450 Front Rims +Holeshot SR Front - Dominator Bumper - UNI Filter - 13/39 Gearing - DID x-ring Chain
2004 TRX250EX
AC Racing Nerfs - Oury Grips - Fmf Slip-on - Uni Filter - Razr Rears
Reece616 is offline   Reply With Quote
Old 02-10-2012, 08:41 PM   #253 (permalink)
Member #417
That is really turning out to be a really NICE looking ride bro.!!!
MOOSE
Franken-Quad Garage
1991 TRX 250X
12:1 Wiseco Piston
Stage 1 Web Cam,
400EX carb, UNI filter,
FMF Power Core 4 full exhaust,
400EX front suspension
THE REST IS A SECRET!!!!
Old 02-10-2012, 08:54 PM   #254 (permalink)
Reece616's Avatar
Member #3038
Thanks man!
I'm loving putting it together and even just looking at it!
I just wish my plastics were in better shape...
2006 TRX400ex
2004 TRX250EX
Old 02-11-2012, 03:07 AM   #255 (permalink)
Reece616's Avatar
Member #3038
The plan today is to get it started, and probably put the front suspension on.
I still have to clean up the front hubs and get the wheel bearings in those as well...
2006 TRX400ex
2004 TRX250EX
Old 02-11-2012, 06:11 AM   #256 (permalink)
chevymuddman's Avatar
Member #12752
View chevymuddman's Photo Gallery(0)
looks good man that orange is bright.If only i could get ahold of some beadlocks. oh the nasty things i would do to em.
92 250x- alot to list
89 300 bayou- cobra pipe
87? 80cc moto 4- stock
chevymuddman is offline   Reply With Quote
Old 02-11-2012, 03:03 PM   #257 (permalink)
Reece616's Avatar
Member #3038
I did a bunch of work today!
I got the handlebar switch on and its looking good.
Chain on (damn master link is a pain in the ass!!)
I put the front shocks and a-arms on, tie-rods, spindles, and hubs.
I put the front wheel bearing in before obviously.
Just like the swingarm bearings, I had them in the freezer, and then tapped them in with the 2x4 and hammer, and finished seating them with a long threaded bolt, washers, and a nut and used my socket wrench and an impact wrench to pull the bearings into proper position. It works great!
Maybe I should make a youtube video of it sometime... hmmm
I'm thinking today (but probably tomorrow) I'll drain the rest of the oil from the case, refill it with new oil, get some fresh gas, and start it up!
It's been too long since i've heard it run!!
I love the way it looks! I couldn't be happier!! Well, I guess if the paint didn't chip at tight clearance areas (a-arm mounts, shock mounts, etc)
What do you think guys?
2006 TRX400ex
2004 TRX250EX
Old 02-11-2012, 03:45 PM   #258 (permalink)
exgofast's Avatar
Member #8729
View exgofast's Photo Gallery(0)
looking good!
NEW WHEELER
  • 2007 400EX BLACK
  • 22' RAZRS ON BACK 22' HOLSHOTS ON FRONT
  • UNI
  • RENTHAL STOCK BEND BARS
2002 honda 300ex
Parts put into it
-2 chains $110
-rear caliper $120
-new tires $35
-brakes $50
-a-arm $40
-bearing $85
-FMF Power core 4 $175
-450r rear axle $20
-400ex front end (arms shocks tie rods) $55
-total: $690
-new skills: priceless
[/B]
SOLD BUT WILL BE MISSED
exgofast is offline   Reply With Quote
Old 02-11-2012, 04:26 PM   #259 (permalink)
Reece616's Avatar
Member #3038
thanks man!
I was thinking about it today, I almost don't want it to be done.
I've had a ton of fun taking it apart and rebuilding it and when it's done
I'll be bored haha...
Well, at least I'll be able to ride haha
2006 TRX400ex
2004 TRX250EX
Old 02-12-2012, 08:11 AM   #260 (permalink)
atvrider13's Avatar
Member #10625
View atvrider13's Photo Gallery(0)
I love how it looks!!
atvrider13 is online now   Reply With Quote
05 honda trx 250ex with holeshots
2000 honda 400ex stock exhaust pic
2000 honda trx400ex
2004 honda 400ex
2006 trx450er
400ex
400ex itp baja black
400ex oem frame
400ex overhaul
400ex pictures
black 400ex
custom plastic 400ex
gbc x rex on 400ex
honda 2001 400ex all black
honda trx 400 ex frame y electronic
orange honda 400ex
paint 400ex frame
paint trx400ex
ss 400ex wheels
the end of a 400ex rear axle
