12-15-2011, 06:00 AM
#1 (permalink)
Member #14056
Bill's 2006 Honda Rancher trx350 rebuild
Well here she goes, I have recently bought a 2004 trx350 that was in pretty rough shape...and by rough shape I mean there is some seriously stupid hillbilly engineering all over this bike, so bad in fact that I am having a hard time figuring out where the original wiring ends and the speaker wires start...YES, I said speaker wires!!! So in order to try and fix this little piggy up I searched around on CL for a donor rancher I could use for parts and what not. Well yesterday I found one, a 2006 Rancher that has been sitting disassembled since last summer and in great shape, and for a decent price! So now I have 2 four wheelers whose sum hopefully equals one completed rebuild, and this is the thread I am starting to document my progress and bounce questions off the professionals, because at this point all I have in my favor is a service manual and an empty garage to work in....
Ok, now here is the scenario and hopefully I can get some input on what I should do. The 2006 rancher was put up because the owner said he got some water and sand in the cylinder and shattered the piston, he said the bike just slowed down and rolled to a stop never seized or anything violent, just died and never started again. So they took the topend out threw it away and left the four wheeler to sit in the barn in parts. When I bought it it had sat outside for a couple days and got some rain water down in the bottom end along with the oil in there. So when i got home I drained the bottom end water and oil and can see all kinds of metal shaving and filings over everything from the piston. Looks like I need to crack the block and seriously clean/wash out the lower end to remove the metal. Maybe some pointers on how to go about this would be good  . The 2004 has not been ran in a long time and will be the donor quad for the 06, I beleive I can get the topend and carb rebuilt from it and put it on the cleaned out 06 for a running engine.......hopefully! This is my first ever rebuild and I am pretty excited and a little nervous, so without further ado here are the pics!!
THANKS BILL
12-15-2011, 07:23 AM
#2 (permalink)
Member #11269
Awesome rebuild project! I think If I were you I'd rebuild the 04 that hasn't sat with water and mud in the crankcase, I'm betting theres some trouble in there. And just part out the bad engine and use it to fund the rebuild...
Kawasaki prairie 400ish stockish
1995 honda fourtrax 4x4, stock.
12-15-2011, 07:49 AM
#3 (permalink)
Member #1660
If you really want to split the case yourself you will need a rubber mallet to beat the crap out of it with. Razor blades to push in between the case halves. (This breaks the seal much easier) and some stiff putty knives to pry the halves apart. Its a tuff job sometimes without a case splitter. Just make absolutely sure that ALL bolts are out.
300 Fourtrax 4x4 2" lift, 14" ss106 wheels, custom Dual chrome snorkels, gear reduction, supertrap ids2, disc brakes, moose seat pack,
12-15-2011, 10:06 AM
#4 (permalink)
Member #7607
try and flush it with diesel first before you split the case....dont use oil, unless you wanna pay out the butt to flush it!
12-15-2011, 04:00 PM
#5 (permalink)
Member #14056
there isnt any mud present in the bottom end that I can see but there is peices of the piston in there, will a diesel flush get those out? Is there any way to get into the case without splitting the halves to look for metal pieces from the piston? thanks
Oh by the way does anyone have a good idea on how to remove the carb heater from the carb? The one I have is on there pretty good!
12-15-2011, 05:40 PM
#6 (permalink)
Member #14099
Very cool project and just get a case splitter it makes it so easy to get it apart.You might try to fill the crank case up and shake it around then drain it out and see if you can get the pieces out that way.just an idea not sure if it will work but it might be worth a try to wash everything out the drain hole.
01 Rancher 350 manual shift 4x4
27" Kenda claws
P&P head
04 250ex Wife's ride
Removed the baffle and rewelded spark arrestor back in,Jetted,Uni-filter
04 YFZ450
Port and Polish,12.5:1,Dyno-jet kit,K&N air filter with custom intake tube,Cam mod,Pro circuit Ti4,GYTR nerf bars.
01 400ex
Port and Polish
Pro Circuit T4
Uni-filter
Dyno-jet 160 45 pilot 2 1/4 turns out
Custom foot pegs
With many things to come
It is a good trail quad with a lot of torque
12-15-2011, 07:26 PM
#7 (permalink)
Member #14056
I am pulling the motor on the 06 right now, once its off I will flush it out real good and see what comes out  . I will post some pics when she comes out...pain in the keister to get all those wires and parts off! Wish me luck.
12-15-2011, 08:57 PM
#8 (permalink)
Member #14174
Man I think I would rebuild both of them !!!!!Lots of fun their !!!!
05 Green Foreman
DGL,2"SS-Lift
Plano green hunting box
11 Green Rubicon
Gscape,power steer
crappy stock tiers
Kolpin hitch
http://youtu.be/i9MhWDPUDHo
12-15-2011, 09:00 PM
#9 (permalink)
Member #7607
thats what i was thinking. rebuild em' both and sell the other and it practically cost you nothing
12-15-2011, 09:01 PM
#10 (permalink)
Member #14174
Ya you bet ,that's what I would do also !!!!!People love them Ranchers !!!!
05 Green Foreman
DGL,2"SS-Lift
11 Green Rubicon
Gscape,power steer
crappy stock tiers
Kolpin hitch
2000 honda rancher 350 engine rebuild kit, 2001 honda 400ex carburetor lines placement, 2004 honda 350 rancher 4x4, 2006 honda rancher, 2006 honda rancher 350, 2006 honda rancher 350 carburetor adjustment, 2006 honda rancher 350 engine 4x4, 350 rancher rebuild, carburetor honda rancher 350, honda 350 rancher lifted, honda foreman carburetor rebuild, honda rancher 350, honda rancher 350 manual, honda rancher 4x4, honda rancher rod, honda rancher valve set starter, honda trx350t fourtrax rancher, modified trx 250ex, timing on 2006 honda rancher trx 350, trx honda quad bikes
