Old 02-10-2012, 09:26 PM   #291 (permalink)
those pic's do not show you the index marks..but..when you pull it all apart...you will see them on the shifting arm and such..and also on the shifting shaft..they all have to line up. before you go tearing it back apart...try going back and re-doing the clutch free play nut/bolt adjustment...lossen the outter nut..turn the center screw all the way counter clockwise..as far as it will turn ..once it stops..and gets tight ?..turn it back 1/4 inch..then tighten down the outter lock nut. if everything is installed right and lined up right ???..and you got the right oil in it ?..and your change clutch disk are not dead ????..then it should move when you put it in gear ????. now..one last question...did you by any chance inspect your centrifugal clutches one-way bearing ??...see if it was ok ??..lol. if it's bad ??????????..no matter what you do right now..won't solve your problem if your one-way clutch for the centrifugal clutch is bad !!..lol.
Old 02-11-2012, 08:12 AM   #292 (permalink)
bnt55's Avatar
Member #14056
View bnt55's Photo Gallery(0)
I dont think its the one way bearing because I had engine braking. No matter what I do as far as clutch adjustment there seems to be clutch slippage, when I tightened the adjustment scew all the way down and backed it out it helped a little but it slipped badly as in I couldnt get second gear to hardly do anything and first would slip when I pushed the throttle. I am going to pull the front cover off the motor and check out my centrifugal clutch, maybe the weights are shot? I checked the clutch plates when I rebuilt the engine and they seemed good no wear and were within spec but I did NOT pull the centrifugal clutch apart, and I think the problem it there. Hopefully I can do this with the plastics on.... Any thoughts?
2006 Honda Rancher 4x4
2004 Honda Rancher 4x4 (waiting for progress):
bnt55 is offline   Reply With Quote
Old 02-11-2012, 09:53 AM   #293 (permalink)
bnt55's Avatar
Member #14056
Pulled the front cover and noticed right away that the clutch adjuster was screwed all the way out and the notch was not on the pin (pic #1) I am sure I did this when I was screwing it counterclockwise and it raised up off the pin, I adjusted it back down tight. Everything looks lined up correctly, kinda hard to see in the confined space. I can turn the centrifugal clutch one way real easily and the opposite way its a little tighter and turns the gears on the change cluctch. I do notice a little front to back play in the cent clutch on the shaft kinda like the nut isnt tightened all the way down, about a small 1/16". The only other thing I can see is there is a some gaps between the plates on the change clutch and I can push them apart and front to back, I dont think they are supposed to be tight unless under a load correct?
What would be causing the clutch slippage? Could it have been the adjusting plate being loose, kinda thought that was for adjusting the shifting only. Little help please
Bill's 2006 Honda Rancher trx350 rebuild-100_3281.jpg   Bill's 2006 Honda Rancher trx350 rebuild-100_3283.jpg   Bill's 2006 Honda Rancher trx350 rebuild-100_3284.jpg   Bill's 2006 Honda Rancher trx350 rebuild-100_3285.jpg
Old 02-11-2012, 02:21 PM   #294 (permalink)
the pin..the one where it was not in the notch that you found ?..that's your problem !!!!..those two parts have to be lined up right !. now..i've got to get outside in this 30 degree weather...and look into my problem !..lmfao.
Old 02-11-2012, 04:45 PM   #295 (permalink)
bnt55's Avatar
Member #14056
Ill put it back together and check it out, it only takes about 15 minutes to pull the cover if its not fixed.
Old 02-11-2012, 05:21 PM   #296 (permalink)
15 min's huh ??..can you do mine in 15 min's ?????????..lmfaoooooo..i wish i had your problem !!..i'd have it made !..lol.
Old 02-11-2012, 09:03 PM   #297 (permalink)
bnt55's Avatar
Member #14056
Well ok I might be stretching it a little... I put the cover back on and adjusted the clutch and I can still hand roll the rear tires while its up on stands when in 1st gear. I think something is up, I am going to take it off again, since Ive had so much practice, and maybe I can get my time down to 13 minutes...hahahaha....gonna pull the cent. clutch and check that one way bearing. is gonna be a bear to get in there to pull then try and stake the lock nut when I put it back. This is kinda like doing open heart surgery through a patients butthole.
Old 02-11-2012, 09:21 PM   #298 (permalink)
Member #7607
View Manny's Photo Gallery(0)
"rectum" to be politically correct LMAO. just think, when your done, you'll be the honda tear down champ. i just did this with my rubicon. trying to get the damn thing aligned. i took off the tie rod's 3x's before my measurements were correct. its all a part of the game man, at least your getting practice!
2001 Rubicon 500 5k+ miles 1100+hours
26 Inch Mudlite XL's, G Force Slammer wheels, Superwinch Terra
Realtree AP Plastics
Warn 2000 Lb. winch
Sedona Ripsaw tires
Fourtrax 300 Parts for sale CLICK HERE
The truth about ATV oil:
http://www.dirtrider.net/forums3/tex.../146867-1.html
Old 02-11-2012, 09:41 PM   #299 (permalink)
when your spinning the rear tires ??..are you going forward ?..or backwards ?..the reason i ask..lol..is they will spin backwards while in gear..but they wont spin forward !!..they are not suppose to anyway !!..if they do ???..then your one-way bearing is bad on your centrifugal clutch !.
Old 02-11-2012, 09:42 PM   #300 (permalink)
i wonder who's gonna get done first ????..lmfaooooooo..first him..then me..now back to him..now back to me with these damn problems !..lmfaooo. sorry bnt..i needed a good chuckle today.
2000 honda rancher 350 engine rebuild kit
2001 honda 400ex carburetor lines placement
2004 honda 350 rancher 4x4
2006 honda rancher
2006 honda rancher 350
2006 honda rancher 350 carburetor adjustment
2006 honda rancher 350 engine 4x4
350 rancher rebuild
carburetor honda rancher 350
honda 350 rancher lifted
honda foreman carburetor rebuild
honda rancher 350
honda rancher 350 manual
honda rancher 4x4
honda rancher rod
honda rancher valve set starter
honda trx350t fourtrax rancher
modified trx 250ex
timing on 2006 honda rancher trx 350
trx honda quad bikes
