12-30-2012, 02:13 PM
#1 (permalink)
Member #26690
2013 rancher 420 sra 2" lift advice
I hope this is in the right area of the forum, i am going to buy a 2" tomorrow at the honda shop ! I am planning on installing myself, im sure there are experienced (do it yourself) type guys on here, how difficult is it to put on, the reason i am going to get this is im about to most likely run 28s
12-30-2012, 04:12 PM
#2 (permalink)
Member #26690
Need a quick reply. I could easily just load it up and let the dealership do it. But u figured it wasn't to difficult. Depending on the type they use
12-30-2012, 05:00 PM
#3 (permalink)
Member #17852
not difficult at all...save the labor charges and do it yourself.
--David
2009 Honda TRX420FPA (mine)
2006 Honda TRX350TM (wifes)
2006 Honda TRX350TE (daughters)
2001 Honda TRX350TE (sons)
2007 Yamaha Rhino 450 (also mine)
ADD ME ON FACEBOOK
"If It Weren't For Physics And Law Enforcement I'd Be Unstoppable!"
12-30-2012, 07:13 PM
#4 (permalink)
Member #26690
So it's simple? Give me more info brotha lol
12-30-2012, 07:24 PM
#5 (permalink)
Member #26690
Should all slide right in
12-30-2012, 09:06 PM
#6 (permalink)
Unbolt whichever end of the shocks it is supposed to mount at,jack the atv up enough to be able to slide the lift bracketry in place,install the old bolts,and the new bolts in their respective places,tighten it all down once it is on the ground to the specs in the kits instructions...30 minutes maybe for a first timer if you have the correct socket set handy,and a floor jack..
12-30-2012, 10:02 PM
#7 (permalink)
Member #26690
Thanks deeper. I really appreciate it. I figured the front end would be hard to mess with. While the rear would be simple due to the shock just being easier to get to
12-30-2012, 10:42 PM
#8 (permalink)
Yes the fronts more of a pain to get to the nuts on some models,but isn't that hard to accomplish with a good jack,tires off,couple of wrenches(ratcheting wrenches make it much easier),and a ratchet set...
12-31-2012, 10:50 AM
#9 (permalink)
Member #26690
kinda aggravated all honda shops around are closed today i called in excess of 150 miles away lol all 4 were closed lol, jackson hattiesburg brookhaven and hammond all closed, i really actually want a 4" lift, anywhere i can find one??
12-31-2012, 11:54 AM
#10 (permalink)
Member #26690
im just gonna order a lift because it willl be a week before i can go get one now, will the highlifter 2" signature lift that fits sra rancher 07-12 fit my 2013?? need a reply if u guys have time
2012 rancher 420 sra lift, 2013 honda rancher 420 lift kit, 2013 honda rancher 420 lift kits, 2013 honda rancher sra lift kit, 2013 rancher 420 lift, 2013 rancher sra or irs, honda 420 rancher sra 2013, honda 420 sra 2 lift, lift kit for 2013 honda rancher, lift kit for 2013 honda rancher 420, what to do to be able to put 30s on a 2012 honda rancher 420, will a lift kit for a honda 420 rancher fit a honda 350 rancher
