Old 04-14-2012, 08:35 PM   #1 (permalink)
jeremy2.2's Avatar
Member #17800
View jeremy2.2's Photo Gallery(0)
Talking 400ex suspinsion and brakes
hey guys im new here an jus starting to mod my 04 400ex. i ran in to the front calipers being locked up! so i heard u can use 450er calipers i found a set of 450er calipers spindals and hubs for 170.00 cheaper than a new stock 400ex set but will they wrk? an if so can i use my 400ex rotors? also if it does can i use 450er shocks as well im looking to lower and widen the front end i found a lowering kit with 1 1/2 to 4 inches of play in rear and 2 to 3 1/2 play in front for 80.00 it also widens the front i was gonna go with extended hubs to widin the rear 3 1/2 cheap and better than spacers iv heard.....im just a trail rider and jump a lil with my buddys thnaks any advice will help
04 honda 400ex
pro taper 7/8ths bars
hmf slip on
14:36 spocket ratio
black bead lock rear wheels
18 rear tires
abc front shoes
red powder coated frame
jeremy2.2 is offline   Reply With Quote
Old 04-14-2012, 08:51 PM   #2 (permalink)
atvrider13's Avatar
Member #10625
View atvrider13's Photo Gallery(0)
I would get a set of used yfz450 front calipers. They bolt right on.
atvrider13 is offline   Reply With Quote
Old 04-14-2012, 08:52 PM   #3 (permalink)
Reece616's Avatar
Member #3038
View Reece616's Photo Gallery(0)
The 450er brakes cost a lot to upgrade. I put of yfz450 front brakes and the bolt on with no modification. All you need is the calipers and pads.
2006 TRX400ex
AC Nerfs - Swingarm Skid + Honda Racing Skid - Protaper Contour Bars - Rox 2" Riser - CBR Clutch Perch - Oury Grips - HT Moto Seat Cover - Custom Poly Case Saver - TRX450R Front Shocks - XR250R CDI - YFZ 450 Dual Piston Front Calipers - ITP T9 Baja Rear + GBC X-Rex - CanAm DS450 Front Rims +Holeshot SR Front - Dominator Bumper - UNI Filter - 13/39 Gearing - DID x-ring Chain
2004 TRX250EX
AC Racing Nerfs - Oury Grips - Fmf Slip-on - Uni Filter - Razr Rears
Reece616 is offline   Reply With Quote
Old 04-14-2012, 08:57 PM   #4 (permalink)
jeremy2.2's Avatar
Member #17800
well see im buying the 450er spindals calipers and hubs for 170.00...that should bolt right up to my 400ex arms right? what maks yzf calipers any diffrent?
04 honda 400ex
hmf slip on
14:36 spocket ratio
18 rear tires
abc front shoes
Old 04-14-2012, 08:58 PM   #5 (permalink)
Welcome to da forums...Just rebuild the calipers you have for under 40 bux total..Compressed air forced into the brake line hole with a block ,or rag between the piston,and caliper,clean piston with very fine emery cloth,and wd40,clean inside of caliper,replace seal,and o rings,and voila,paint em to have 2 like new calipers that will last you as long as buying new ones,and save you enough moolah to almost pay for the extended axle,or wheel spacers,or axle extension hubs....
Old 04-14-2012, 09:03 PM   #6 (permalink)
jeremy2.2's Avatar
Member #17800
well the part of the calipers that r locked up is not the plunger part it the slider on the mounting bracket that makes the indacator move i can get the new pads in fine but the bracket wont move to alow for the rotor to squeez between them.... and the allen wrench is so siezed up i broke two wrenches on them i c clamped them bent c clamp and i put channle locks on them an let them soak in wd 40 over night didnt budge !!! so time for new ones an they run from 60 to 100 a pair i figured the 450er parts were a deal !
04 honda 400ex
hmf slip on
14:36 spocket ratio
18 rear tires
abc front shoes
Old 04-14-2012, 09:04 PM   #7 (permalink)
atvrider13's Avatar
Member #10625
You can get Yfz450 calipers alot cheaper than $170.I got mine for like $35 used.
Old 04-14-2012, 09:07 PM   #8 (permalink)
Try some PB blaster overnight as wd40 nowhere near as good at soaking into,and lubricating...
Old 04-14-2012, 09:10 PM   #9 (permalink)
jeremy2.2's Avatar
Member #17800
yeah but my point is im not just gettin calipers im getting hubs and spindles ass well.. i just wanted to know if it would work with my rotors if any body knew i already no that yzf calipers will... im wanting to do a 450r swing arm conversion also
04 honda 400ex
hmf slip on
14:36 spocket ratio
18 rear tires
abc front shoes
Old 04-14-2012, 09:11 PM   #10 (permalink)
jeremy2.2's Avatar
Member #17800
my calipers r trashed the c clamp messed them up
04 honda 400ex
hmf slip on
14:36 spocket ratio
18 rear tires
abc front shoes
400ex front right caliper
400ex lowering kit for trails
400ex trail mods
400ex wheel lowering kit info
breaks on 400 ex got stuck in did them but now my brakes dont work
cheap way to widen banshee
extended rear axle 2006 honda 400 ex
holeshot honda 400 yellow powder coated red
honda atv front brake pad stuck
how to extend front end on 400ex
spacers on 400ex
the front wheels on my 400ex are stuck on
