How to fix sticking rear drum brakes - Honda ATV Forum
post #1 of 23 (permalink) Old 04-08-2012, 12:23 AM Thread Starter
Liked: 54 times
We see a lot of people asking why their rear drum brakes are squealing,sticking,locking up,or simply not working properly... I found this very well made,and explanatory video that shows what we've been trying to type into words so often on here in answer to the many questions...Watch it all the way through,and you too can perform your own rear brake repairs !!! Honda TRX 400 brake repair - YouTube
Deeperinthabush is offline
post #2 of 23 (permalink) Old 04-08-2012, 12:51 AM
Good info. Made this a sticky.
post #3 of 23 (permalink) Old 06-16-2012, 04:06 PM
outdoorman's Avatar
great video but Ive got a 2004 honda recon and am stuck in the middle of trying to figure out how to separate the brake panel plate from the drum. they came off together when I tried to get the panel plate off. also the brake lever at the panel cover was nearly frozen and I could only move with mallet. thanks
outdoorman is offline
post #4 of 23 (permalink) Old 06-16-2012, 05:54 PM
sabre54's Avatar
You'll probably have to saturate it with wd/40 or some kind of solvent, then oil, the shoes are seized against the drum, may take a few days of soaking, then try to work it off slowly, one caution, you can't hit the drum or the backing plate with anything but a rubber mallet or you could crack the drum/damage the backing plate. With the soaking, there may be better products out there, I just don't know what.
1996 Foreman 400 FW, 2007 420FM Rancher,2008 420FM Rancher,2009 Foreman 500 FPM
sabre54 is offline
post #5 of 23 (permalink) Old 06-16-2012, 09:28 PM
HondaGav's Avatar
Liked: 64 times
I just connected a spring from the brake lever to the frame, Works like a charm.
-2007 King Quad 450 (Work Horse)
-1984 Honda TRX200 (Donor)
-1989 Skidoo Mach 1 (Play Toy/Winter Headache)
-1966 Series IIA Land Rover (Major Project)
HondaGav is offline
post #6 of 23 (permalink) Old 07-04-2012, 12:02 PM
outdoorman's Avatar
Sabre54- thanks for the good advice, it worked like a charm and I have completed reassembly.
I just did like in the video to replace my rear drum brakes on 04 Recon. Now the problem is that the brake cam lever has to be pulled all the way in order for the brake to stop. That is, I have to adjust the cables at the cam lever nearly all the way in order for the brake to work. Any suggestions?
By the way, I made sure the 'marks' line up when I put the cam lever back onto the (brake panel)cam.
What should I do now?
post #7 of 23 (permalink) Old 07-19-2012, 08:11 PM
outdoorman's Avatar
anyone got any thoughts on how to fix this problem. Ive got the recon still up on a lift since last post.
post #8 of 23 (permalink) Old 07-19-2012, 09:28 PM
Your brake drum might be wore a lot. You can try removing the brake lever from the cam and rotating it forward a spline or two on the brake cam.
post #9 of 23 (permalink) Old 07-31-2012, 11:38 PM
hawaii50's Avatar
I have a suzuki LT250ef it has a sticky brake. Is fixing it anything like your honda thx 400?
hawaii50 is offline
post #10 of 23 (permalink) Old 09-09-2013, 06:10 AM
cheiderman's Avatar
great post, I had a similar issue where my rancher rear brakes were not working. I pulled of the cover/drum and dumped about 12 oz of water. I found my son had used my quad and about sank it. That was a few months ago so all the water in there had seized and corroded the entire brake Assembly. I ended up braking the shoes off as they were frozen. I had to chisel off the shoes parts on the posts.
cheiderman is offline
