Is the Foot Brake adjustable - Honda Rincon - Honda ATV Forum
post #1 of 10 (permalink) Old 03-26-2011, 08:27 AM Thread Starter
c5ken's Avatar
Can I adjust the foot brake on a 2003 Honda Rincon 650?
The rear hand brake workes great but when I only apply the foot brake, I have little to no braking. Help..
c5ken is offline
post #2 of 10 (permalink) Old 03-26-2011, 10:26 AM
Liked: 226 times
i have a 03 rincon too and i looked through my manual and i could not find a rear brake adjustment. have you checked the rear brake fluid? its under the side cover on the right side of your seat. also, maybe it needs to be bleed?
Manny is offline
post #3 of 10 (permalink) Old 03-26-2011, 01:01 PM
Yeah, I don't think you will find an adjustment, since you have disc brakes. Like Manny said, check the brake fluid and if it's full, you might need to bleed the brakes.
post #4 of 10 (permalink) Old 03-27-2011, 07:51 AM Thread Starter
c5ken's Avatar
Prior to asking the above question, I disassembled the rear brake, pulled the pads & checked everything out. All appears to be in order. I also replaced the brake fluid in the front & rear brakes. The fluid was honey color & had some little white junk in it. The brake fluid in now clear. After I did the above, the brakes work great when using the hand levers. However, when in 2WD & I hit the foot peddle, I have little to no brakes. I was hoping there was an adjestment for the foot brake peddle....
c5ken is offline
post #5 of 10 (permalink) Old 03-27-2011, 10:52 AM
Liked: 226 times
maybe you possibly have some gunk in the brake lines? not sure just trying to think of some ideas
Manny is offline
post #6 of 10 (permalink) Old 03-27-2011, 01:57 PM
Ballast's Avatar
Liked: 31 times
Just read the manual, I can't see anything about foot petal adjustment. Looked at mine and I thought the nut below the master cylinder may be the thing but I guess no. Are the bushings or whatever where the foot petal rotates loose?
4 HONDAS 4 ME
85 TRX125.... sadly sold
Ballast is offline
post #7 of 10 (permalink) Old 03-27-2011, 07:07 PM Thread Starter
c5ken's Avatar
I CHECKED THE FOOT PEDDLE LINKAGE TODAY & EVERYTHING APPEARS TO BE IN GOOD CONDITION.
I think I'll buy a MityVac & suck out the brake fluid again. I'm not sure what that white junk was/is when I changed out the break fluid several days ago.
Has anyone ever used a MityVac when changing out break fluid?
As I stated in my prior note, when I changed out the break fluid last week, it was honey color & had some white particles in it. Is it normal for old break fluid (7 years old) to be honey color?
c5ken is offline
post #8 of 10 (permalink) Old 03-27-2011, 07:51 PM
Ballast's Avatar
Liked: 31 times
The fluid darkens with age until it gets nearly black. My Porsche recommends changing every 2 years to maintain optimum braking, brake fluid absorbs atmospheric water and will then boil at lower temperatures when really hard repeated braking (track stuff).
White chunks ????
4 HONDAS 4 ME
Ballast is offline
post #9 of 10 (permalink) Old 03-28-2011, 06:13 AM Thread Starter
c5ken's Avatar
I'm not sure what the "white chunks" were in the old brake fluid. The white chunks with about 1/16" long. I think most of the junk came out when I replaced the break fluid.
I can get a MityVac on the Internet for about $30.00. Maybe if I use the MityVac to suck out all of the break fluid again it will clear the lines.... Just wish I could get a good solid foot break petal. What is confusing to me is when I apply the rear breaks via the hand lever I can lock-up the rear wheels. When using the foot petal only in 2wd, I can't lock the rear wheels.
Thanks for all of the help/suggestions. Maybe I'll call Honda & see if they have any suggestions....
c5ken is offline
post #10 of 10 (permalink) Old 03-28-2011, 07:31 PM
Banned
elmerkit's Avatar
Also check for the wear and tear of your brake pads and change your fluid regularly.
elmerkit is offline
