Is a 04 650 Rincon subject to ES probs? - Honda ATV Forum
post #1 of 10 (permalink) Old 12-01-2013, 12:08 PM Thread Starter
hammer0630's Avatar
Liked: 5 times
I was reading a post about some of the Honda Quads having problems with the ES shifter. I'm not familiar with the whole Honda line of quads and their transmissions but my 04 Rincon has ES shift buttons on the left handlebar and a metal shift lever for reverse, neutral and forward and can be manually shifted or put into automatic. Also does my quad have a angle sensor? Thanks!!
hammer0630 is offline
post #2 of 10 (permalink) Old 12-01-2013, 12:16 PM
Liked: 240 times
All honda Electric shift models have an angle sensor.
As for your 2004 being problematic. In short -> NO < -
As long as you keep your ES model out of the ponds and rivers, and keep up on periodic maintenance, as well as fixing issues that may arise right away. You should have years of trouble free service.
I have a rancher 350 ES in the fleet that just turned 11,700 miles, and the ES has been working flawlessly.
Manny is offline
post #3 of 10 (permalink) Old 12-01-2013, 12:23 PM Thread Starter
hammer0630's Avatar
Liked: 5 times
Does your Rancher also only have 3 gears? Trying to find out more about Honda's line up. Never knew it had a angle sensor. I have had my Rincon in a few situations that it was almost on it's side a few times and it never quit running. Thanks.
post #4 of 10 (permalink) Old 12-01-2013, 12:26 PM
Liked: 240 times
No, this rancher has a 5 speed transmission. Pretty standard (like most of the other honda's)
Its not automatic, just 5 speed with reverse.
They produced them from 2000-2003. In 2004 they came out with a new look for the rancher 350, same engine and running gear, just different cosmetics.
Manny is offline
post #5 of 10 (permalink) Old 12-01-2013, 02:21 PM
kentco's Avatar
Liked: 1457 times
Sir, the Rincon does not have a shift motor. But, even if it did, it would still NOT be inclined to have problems (just as Manny indicated).
Eight times as many ES shifted Honda units are sold for every one footshift. Thus, one would expect to see eight times as many problems with ES as with footshift. (If there were/are eight times as many problems with ES reported for every one footshift problem reported, that would mean that they are EQUAL in reliability. However, it is a fact that the ratio is much lower (maybe 3 or 4 ES issues reported for every Footshift issue reported.). Doing the math, that says ES is more reliable and troublefree than footshift. However, when people see that there are even twice as many ES issues reported, they instantly assume that ES has twice as many problems.
If there was a forum about Pickup Trucks, then you would see more issues with Ford than with any other truck. Does that mean Ford is more problematic? Absolutely not. And that's because there are a lot more Fords on the road than there are of many other trucks.
As Manny said, the vast majority of ES issues come from people who have used their ES Honda in a way that Honda recommended against - such as in deep water.
Honda has made the ES shifting for around 13 years now. If it was problematic, they would have either discontinued it, or changed it - and they have done neither. When you read post from people who speak down on ES machines, you're reading post from people who assume that because they have seen twice as many issues with ES, that ES must be bad. Again, if you saw eight times as many issues with ES as with footshift, then it would be an indicator that the two are equal. ONLY if you saw 9 or more ES issues, for every one Footshift issue could you honestly assume that Footshift was/is better.
Hammer....on another note, yes, the Rincon only has 3 gears. However, it has a stronger engine. I have both a Rincon and a Rancher and either can go wherever the other can go. So, what is the difference. The big difference is weight (the Rincon weighs more). Therefore, I use the Rincon to plow with and to do heavier work with. The Rincon is also an excellent trail, and all-terrain machine. It really depends on what you are looking for and how you're going to use the machine. As I say, each machine will easily keep up with the other.
Hope that helps.
kentco is offline
post #6 of 10 (permalink) Old 12-01-2013, 02:35 PM
jdp
jdp's Avatar
Liked: 75 times
Ditto, all in what ya want. I can go almost anywhere with my 300 2wd that grandpa can go on his 4wd 300 but the only thing stopping me is ice and clay mud, and steep hills but we dont have steeps on out land, most are about 35* on our property. But I use mine more than grandpa's, I'll have to chain up soon cause of ice and deep snow.
1993 Honda 300
Seafoam "In every tank"
Superwinch Terra 35/synthetic rope, KFI winch Mount.
AMS Swampfox front 23x8x11, GBC dirt devils 25x12x9 rear.
jdp is offline
post #7 of 10 (permalink) Old 12-01-2013, 07:57 PM
mac102004's Avatar
Liked: 1093 times
Rincon's do NOT have an angle sensor, it does not share any components with any of the other models with ES, except the handle bar buttons. Therefore it's not plagued with all the issues of the other ES models either.
ES models are prone to failure. It's a fact, some people have a hard time swallowing their Honda pride and admitting it. But ES is a garbage system, and I would never buy one. Footshifts have no issues with the shift mechanism, unless of course you break you ankle. So if Honda sells 10 footshifts, and 80 ES models, and there is ZERO problems with the foot shifts, and ONE with the ES then they are less reliable, period.
The angle sensor isn't literally an angle sensor that shuts the motor off. But all the EFI Honda's do have a "bank angle sensor" that will shut the engine off if it goes over 70 degrees I think it is. I've had a 500 Foreman EFI shut down on me before. Your 650 wouldn't have one, but the 2006+ 680's do.
2015 Honda Rubicant FM7
- 27" Bighorn 2.0's
- Powermadd Handguards
- ODI Grips
- 31x11" Outlaws
- NPP Dual Dominators
- ECM Reflash
- TheBOM Mag+ Cams
- TwinAir Air filter
- Delrin Motor Mounts
- Aluminum Valve Covers
- Gorilla Through Shaft
- TigerTail
mac102004 is online now
post #8 of 10 (permalink) Old 12-01-2013, 10:50 PM Thread Starter
hammer0630's Avatar
Liked: 5 times
Thanks for the info Mac!
post #9 of 10 (permalink) Old 12-02-2013, 10:53 AM
RobK's Avatar
I love the ES on my Rancher and Forman. However they are not like the Rincon. The Rincon has an automotive style 3 speed automatic transmission with a torque converter, etc. Shifting it manually with the ES buttons would be analagous to shifting your automatic car with the floor shifter. The Rancher, Foreman, and (I believe) Recon ES models have a 5 speed manual style transmission that has an added electric motor to do the shifting for you. It's really a very simple design and it works very well. However it can be subject to some electronic gremlins with the angle sensor or control unit. Bad connections can make it act wacky.
RobK is offline
post #10 of 10 (permalink) Old 12-08-2013, 07:26 PM
Toytec's Avatar
The ES systems are not prone to failure any more than foot shift quads are.
Why does everyone who doesn't have this have to post they are problematic when they (You) have had no personal experience with the ES?
2004 TRX450R
TWO 2000 Polaris 500 sportsman's
2006 Foreman 500
ITP SS108 wheels with 27" Kenda Bearclaw Tires
2" lift
Superwinch 3500 Terra
60" Warn Provantage plow when needed!
15" LED light bar!
3 light HID upgrade
Toytec is offline
