03-09-2010, 04:26 PM
#11 (permalink)
Member #1660
Originally Posted by Billy250X
If you used a two stroke the crankcase and the tranny are split from eachother by a aluminum casting so just remove the crank and you'd be good to go.
Now were talking I didn't even think about the old 2-strokes, That should work really well!
300 Fourtrax 4x4 2" lift, 14" ss106 wheels, custom snorkel, supertrap ids2, disc brakes, moose seat pack,
A CNN reporter once asked an Army sniper what he felt after killing a terrorist. He shrugged and said RECOIL.
03-09-2010, 04:32 PM
#12 (permalink)
Member #2289
... are there any utility type ATVs that are two stroke and have this "feature"?
/crosses fingers
Off I go to look for information on Honda's 2 stroke ATVs!
03-09-2010, 04:51 PM
#13 (permalink)
Member #1660
Honda made the old threewheelers in 2-stroke that were utility
03-09-2010, 04:54 PM
#14 (permalink)
/crosses fingers
Most, if not all of the 2 stroke utilities, are made by Polaris and have CVT belt drive transmissions. Then you have the old Honda Oddysey, they were 2 stroke, but they had a CVT transmission, also.
I would have thought that the CVT would have been the best way to go. I believe you can buy a stand alone CVT for the application that you are attempting. I don't know the specifics to your project, so I guess it might not be the right transmission to go with.
Everyone's entitled to their own opinion, even though mine is right and yours is wrong.
03-09-2010, 04:59 PM
#15 (permalink)
Member #1088
Your best bet is to find a good blaster bottom end.Yes I know that it is not a honda but they are a really good bottom end unit.
Billy
1991 Trx250X Custom exhaust,K&N jetted,widened 5.5 inches in the back.Way more to come.
Building things makes me happy.
03-09-2010, 05:25 PM
#16 (permalink)
I wonder why he wants a utility? Maybe shaft drive? It's going to be hard to find a 2 stroke with shaft drive. Is he wanting just an automatic or is he wanting the semi-auto with the centrifugal clutch, like the 300 Honda utility? Does it have to be Honda? I read the post, but I'm still not clear on what he wants. I guess, maybe, he's not decided exactly what he's looking for, yet.
03-09-2010, 06:04 PM
#17 (permalink)
Member #417
Cintrifigal clutch system from a golfcart will work.. The best thing to run would be Hydrostatic IMO? a pump, a pedal, a function manifold or flow divider and a couple of coils
MOOSE
1991 TRX 250X
12:1 wiesco piston @ 60 over
stage 1 cam,
Vesra connecting rod
High performance coil
jet kit, 400EX carb, K&N filter,
FMF power Core 4 full exhaust,Tusk nerfbars.
Coming soon Ported and polished headECT. ECT.
03-10-2010, 11:33 AM
#18 (permalink)
Member #2289
The reason for wanting the utility type buggy is that a wide range of gear ratios is needed for the speeds we might encounter on a race track. With our puny little engine, it would be great to have a 1st gear with as high of a ratio as ~4.2 so we can use the little torque we've got to get up a rock crawling section. Then after that, we might have to ride on a high speed series of turns at 35 mph, so it would be great to have a high gear with as low of a ratio of 0.78.
The problem with the Honda ATVs is that we are running TOO wide with too few gears, I think. When we shift from first to second, the RPM will go from 3800 to ~2100, which will drop us from ~10 hp to ~5.5 hp. This won't be good if we encounter a steep hill climb from a stop.
Utility ATVs usually have the best gear ratio ranges inside the gearbox. Sure we can change ratios via a final drive, but we would only lower our top speed or raise our top speed in first gear, both of which might be unacceptable if we come across the Nurburgring of buggy tracks.
Aside from that, this transmission might end up being used on a "utility" buggy of sorts. While some people in the group want to make a full race vehicle with wide ratios, 6 gears, and no reverse, it's my opinion that we want to have a wide range of gears and we MUST have a reverse. The buggy a couple of us are kind of splitting off and designing will have things like a charging system, headlights, a winch, storage capacity for tools on the trail we test on, etc. Essentially, it will be the workhorse for when the other one breaks or wrecks. Thus the clutch must be equipped to handle the high loads that it might see, and a utility ATV that weighs close to 600 pounds AND is designed to tow 800 or so will certainly cover what I think we need.
An auto clutch is a nice bonus, but also could be a con. I'm still kind of up in the air about that one. I don't like taking control away from the driver, but it would be nice to have a buggy that anyone can drive.
03-10-2010, 03:36 PM
#19 (permalink)
Member #2063
Wow this certainly is interesting, I can't wait to see how this pans out. I love following projects like this. Welcome to the Forums and keep us up to date!
1988 FourTrax 300
03-10-2010, 03:51 PM
#20 (permalink)
Member #1088
Yeah man keep us up to date.
Billy
» Site Navigation |
» Honda Forums
