Rear Brake Drum seized - Honda ATV Forum
Old 09-30-2012, 06:56 PM   #1 (permalink)
sprocket's Avatar
Member #23277
View sprocket's Photo Gallery(0)
Trying to get the axle off a 1984 ATC110. Got the hubs off, axle nuts off that were tight against the drum and the brake drum is seized in place. Squirted inside with some WD40 and letting it sit. Not real familar with the brake drum inside diameter feature. Is it splined onto the axle? Do I need to pull the drum straight off, or can I twist and pull. This has been a tuff one. Thanks in advance.
sprocket is offline   Reply With Quote
Old 09-30-2012, 09:42 PM   #2 (permalink)
Liked: 52 times
Look where the drum meets the axle,there's a tapered washer down there (possibly an o ring also)that hasta be removed,and the brake cable nut removed allowing the shoes to sit in the neutral position...If the linings have come free of the shoes,then you have to work the drum back n forth quite forecefully to get the linings to move away from the locked position first,then wiggle the drum while (GENTLY) prying against the opposing side of the drum with a small prybar..
Old 09-30-2012, 10:18 PM   #3 (permalink)
sprocket's Avatar
Member #23277
Thanks - let you know when I got her free.
Old 09-30-2012, 10:20 PM   #4 (permalink)
Liked: 52 times
You're welcome....
Old 10-01-2012, 11:55 PM   #5 (permalink)
Christopher11's Avatar
Member #23959
View Christopher11's Photo Gallery(0)
My experience said that about this problem Look where the drum meets the axle,there's a tapered washer down there (possibly an o ring also)that hast be removed,and the brake cable nut removed allowing the shoes to sit in the neutral position..
lift kits
Christopher11 is offline   Reply With Quote
Old 10-07-2012, 08:57 AM   #6 (permalink)
sprocket's Avatar
Member #23277
Spent a good number of hours getting this one free. Ended up removing the bearing assembly and axle from the frame. Had to grind off one of the bolts that attached bearing assembley to the frame - the weld on the nut inside the drum broke and the bolt was captured.
Once I got the housing and axle free from the frame, I was able to tap on the drum through the two holes where the bearing housing attaches to the frame. Eventually got things free and didn't wreck anything in the process.
Turned out the bearings were seized and the shoes were rusted to the drum. A real basket case. But I got what I was after which was the rear axle and bearing housing. My plan is to use these parts as part of a custom build I'm working on. It's going to be a minature police trike based around a Honda Z50 frame. When done, I want it to resemble an old Harley Servi-Car circa 1940 and be a minature version.
Thanks for the help so far.
Old 10-07-2012, 03:12 PM   #7 (permalink)
starmac's Avatar
Member #10275
View starmac's Photo Gallery(0)
Liked: 4 times
Sounds like a cool project.
starmac is offline   Reply With Quote
Old 10-07-2012, 07:53 PM   #8 (permalink)
Liked: 52 times
You're welcome..I forgot about that little project you were building...
atc 110 brake removal
atc 110 remove brake drum
honda 110 atc brakes locked
honda 110 atc rear brake removal
honda atc 110 axle removal
honda atc 110 rear axel
honda atc 110 rear axle not straight
honda atv rear brake drum
honda atv rear brake siezed
honda foreman forum rear brake hub seized on
how to remove brake hub on atc 110
remove atc brake drum
