04-14-2012, 08:29 PM
#1 (permalink)
Member #12074
Best Degreaser
I am having a time getting the grease out of the axle tubes on my 450 that I am rebuilding. I tried Purple Power from Auto Zone and it doesn't seem to be cutting it. These tubes have a good bit of mud, dirt, and grease. What degreaser or method would y'all suggest?
04-14-2012, 08:31 PM
#2 (permalink)
Member #8144
Carb cleaner works good for me at work. Also, gas is good to.
2011 Rancher 420 FPM
AMS Swamp fox tires
Stearns rear rack bag
Superwinch Terra 25
Moose rear bumper
04-14-2012, 08:33 PM
#3 (permalink)
Member #11909
off brand yellow cap oven cleaner
2004 400ex
yoshimura slip on
uni filter
426 kit
moose bars
dg bumper
msr clutch
itp c-series rims
04-14-2012, 09:16 PM
#4 (permalink)
Member #14099
Oven cleaner will also take off paint if it is left on too long,but It works really good if you spray it on and let it sit for a minute and spray it off.also if you have graffiti on your car it will take it off too but will not damage the paint if you don't leave it on.I bought a truck that had some advertizing on it so I use the oven cleaner and it came right off.
04 250ex
06 yamaha Wolverine 450
03 recon
04-14-2012, 09:25 PM
#5 (permalink)
You can also clean the tubes by soaking a large rag in diesel fuel,running/pushing the rag through from one end to the other several times to break up any petroleum products inside the tubes,spray each tube with that Purple Power degreaser full strength,allow to soak for awhile,pressure wash them out using soap,and water,and they'll be as spotlessly clean inside as they were when new...
04-14-2012, 10:40 PM
#6 (permalink)
Member #10220
paint thinner works great too.
04-16-2012, 06:21 PM
#7 (permalink)
Member #16949
i bet mineral spirits would desolve it really quickly. if you ever roof a house and get tar or your fingers...nothing takes it off as fast as mineral spirits.
2005 Honda Rincon. Stock.
New tensioner, tensioner lifter, cam chain, oil chain, knowledge on how to replace these? Priceless.
Mobile 1 4T lets this quad shift nearly undetectable.
Coming soon: Executioners!
After all, a hole - is a hole - is a hole. Richard Burton "Where Eagles Dare".
04-16-2012, 06:25 PM
#8 (permalink)
Member #10220
That is true I use it allthe time to take grease off that is why I recommended it,being a gas fitter I am use to grease and oil
04-16-2012, 07:18 PM
#9 (permalink)
Member #417
pressure washer with a roto tip is the bomb I wished that i had one again
1991 TRX 250X
400EX carb, UNI filter,
Secret engine ingredients
FMF Power Core 4 full exhaust,
400EX front suspension
450R front shocks,LT250R rear shock
Custom oil cooler
check it out
http://www.hondaatvforums.net/forums...-makeover.html
04-17-2012, 09:14 PM
#10 (permalink)
Member #16949
falcon...when you mentioned paint thinner the first thing i thought of was lacquer thinner...then i remembered the mineral spirits can be used also. cool.
atv degreaser, best atv degreaser, best degreaser, best degreaser for 4 wheeler, best degreaser for atvs, degreaser for a fourwhweeler, degreaser on atv chain, dg500 degreaser, good degreaser for four wheelers, using degreaser on atv, what is the best degreasing soap to wash atv, whats the best degreaser for 18 wheeler
