Oil Temp Sensor - Honda ATV Forum
Old 03-26-2012, 06:49 PM   #1 (permalink)
BWT
BWT's Avatar
Member #17253
View BWT's Photo Gallery(0)
Oil Temp Sensor
I need a Oil Temp Sensor for my 2001 Foreman 400...can I buy one online? Having trouble finding one.
Thanks,
Brian
BWT is offline   Reply With Quote
Old 03-27-2012, 12:05 AM   #2 (permalink)
Welcome to the forums. Yes, you can order one online. Click on the link below and the oil temp sensor is #7 in the schematic. It's Honda part # 37750-HC4-751.
2001 Honda TRX400 FOREMAN 4X4 OEM Crankcase Parts | MotoSport
Old 03-27-2012, 05:45 AM   #3 (permalink)
BWT
BWT's Avatar
Member #17253
Sensor
I guess it pays to know where to look...Thank You
Old 03-27-2012, 01:32 PM   #4 (permalink)
BWT
BWT's Avatar
Member #17253
Another Question
I guess before I spend 50 plus bucks I should at least ask if I'm on the right track. First off we're dealing with a 2001 Foreman 400 4X4 that I just picked up. I've run the engine enough that I feel pretty certain that the cooling fan should have come on. I checked all the wiring and connections and everything seems okay. I then removed the wire from the oil sensor and ground it to the engine, the fan run fine and the oil light also came on. Is it a safe bet that replacing the sensor will fix the issue or is there something else I'm missing? How hot do these things have to get before the fan runs?
Thanks Again,
Brian
Old 03-28-2012, 12:48 AM   #5 (permalink)
The engine has to reach approximately 300 degrees F. before the fan will come on. If the engine is, in fact, reaching this temperature, then I would say your oil temp sensor is bad. You usually have to run them pretty hard to reach that temperature, though. Or running slowly in low gear for a while will usually make the fan kick on, too.
In the service manual, there's a procedure shown for testing the oil temp sensor. It involves submerging the oil temp sensor in oil and heating the oil to a couple different temperatures and then using an ohmmeter to measure resistance across the sensor terminal and the body of the sensor. I will find the procedure and post it for you.
Old 03-28-2012, 12:53 AM   #6 (permalink)
2000 honda foreman oil temperature sensor
2001 honda foreman 500 temp sensor location
37750-hc4-751
at what temp should the fan turn on on a honda 2000 trx450s
honda 450es foreman oil sensor part
honda foreman 450 oil temp sensor
honda foreman oil temp sensor
honda oil thermosensor 1999 honda foreman 450
oil scentors on honda quads
oil temp sensor 2000 honda foreman 450
oil temperature sensor for 2008 foreman 500
oil thermo sensor foreman
