Yukon Down, AWD delete, headers, converter etc... - Honda ATV Forum
 1Likes
post #1 of 19 (permalink) Old 05-29-2016, 03:04 PM Thread Starter
01SSRedA4's Avatar
Liked: 24 times
So here she is, 2004 Yukon XL, family hauler, Camaro hauler, been my daily driver for the last two years.
I want something that can tow my car with ease, tow other stuff, and generally be usefull. I already have a good tune, efan conversion, and cold air intake.
I figured this conversion may take a while so I bought another daily driver to cover me while the yukon was down.
I figured, I could get a little performance by deleting awd, and by selling the components could offset the price. Once I assembled all the parts, I jacked her up.
First things first we must remove all awd components....this is the non-electronic transfer case. It splits power 70/30 rear/front at all times.
And it weighs about 70lbs.
4wd 4l60e. Looks to be original.
Here's the stock setup.
06 Foreman 500 - 29.5 OG Laws, SS212s, 35%, Warn 2.5k, HL^2", <2.5">, EPI, HMF
95 Fourtrax 300 - 27" Zillas, SS212s , Viper 3k, HL^2"
04 XR80 - Stock
07CRF50 - Stock
01SSRedA4 is offline
post #2 of 19 (permalink) Old 05-29-2016, 03:05 PM Thread Starter
01SSRedA4's Avatar
Liked: 24 times
The stock torque converter.
And it weighs about 52lbs.
Front diff about 80lbs.
Front axles.
Lot's of room under here now.
Lots of people say/think you cannot run a 4wd/awd hub on a 2wd truck. They say if the axle is not there clamping it together the hub will fall apart. After inspection it appears that what the axle clamps in the front and rear is the same solid piece, meaning it cannot come apart.
Also if you notice by looking at the axle end there is no abs, meaning everything will function normally with it removed. The abs is in the hub itself.
I also thought this truck had a bad head gasket. Looky looky, a certain stain going down the cylinder head of a leaky steam port. Winning!!!
Some goodies, a built 2wd 4l60e from my buddy Tim Frost @ Pro1 Transmission in Texarkana.
And this pretty thing right here. Its a 2800/3k unit from Circle D.
Smaller then stock.
04 XR80 - Stock
07CRF50 - Stock
post #3 of 19 (permalink) Old 05-29-2016, 03:06 PM Thread Starter
01SSRedA4's Avatar
Liked: 24 times
Lighter then stock.
Not gonna hunt down a 2wd crossmember, so I made my 4wd work. The 2wd trans sits about 3 inches higher so I made a small bracket and welded it to the 4wd crossmember.
So here it is mounted up, using a $10 2wd Anchor mount.
The last piece of the 2wd puzzle. An aluminum shaft, 4 inch, .125 wall and 69 3/8th" center to center. I bought this from a driveshaft place in California but you can get a used one off a 2wd version off a wrecked truck, but beware they are hard to come by. Can for size reference.
Another little treat. These are 1 3/4 from Speed engineering. Fit was ok, nothing to get upset about...I did clearance them a bit to get the clearance I wanted.
Trying to get headers on by yourself isnt fun. I made two studs, inserted them so the headers and gaskets had something to hang on. I used the wire to hold the collectors up. I went with GM MLS gaskets to seal em up.
Here's a picture of the muffler and merge. Dynomax bullet and Magnaflow merge. I had it on the truck before and it sounded loud but with a nice tone.
Now that she's back on the ground and running I will give some driving impressions. The converter foot breaks to 26/2800 and flashes from a stop to 3k. To get moving you spin about 2k rpms. The converter feels nice and pulls good on the top end. The headers perked up the midrange and you can especially feel it over 4k, where the stock setup seemed flat and out of steam. And no my front tires didnt fall off even though the internet said they would! I will be pulling the intake soon and fixing the coolant leak and freshening up the top end.
04 XR80 - Stock
07CRF50 - Stock
post #4 of 19 (permalink) Old 05-29-2016, 03:07 PM Thread Starter
01SSRedA4's Avatar
Liked: 24 times
Wanted to give this thread an update....I needed to fix the leaking coolant from the crossover line. So I jumped into intake gaskets and whatnot also. Here it is, cold air, efans, and stock otherwise. Also removed the wide Denali engine cover. I dont like everything covered up.
This thing is filthy. Its not so much a leak as it is just weeping from all the seals just a tiny bit over a 200k mile course.
Got the intake removed in about a hour, pretty simple stuff.
A little purple power and elbow grease goes long way.
Showing my fbody roots, I decided to do a throttle body coolant bypass, I had this brass barb in the tool box so I plugged it into the line going to the throttle body. Here you can also see the valve covers which I spent about an hour cleaning.
Since these trucks are known for having rear knock sensor issues due to moisture I decided to do a new ac delco rear sensor, new Dorman harness, valve cover gaskets, intake gaskets just to kind of freshen things up. My stock sensor appeared fine.
We had some kinda crappy weather, but I caught this guy hanging out behind the shop for about half an hour.
On order from Jegs, to quiet things down some. I am gonna install it inline with the bullet muffler.
And a couple of random pics, this is a 4wd/awd transmission mount.
Manifolds.
Front drive axles.
Stock down pipes with Magnaflow cats.
04 XR80 - Stock
07CRF50 - Stock
post #5 of 19 (permalink) Old 05-29-2016, 03:48 PM
mrbb's Avatar
Liked: 925 times
looks like you got a heck of a project going on there
in my neck of the woods, NO one would ever remove a 4x4, to make a 2x4 LOL
but I guess your in dry more flat lands and don't have to worry about snow and ice and slippery hills??
I have known of a few guys that added turbos to them trucks and could get up over 500 HP at the rear wheels with some larger injectors and better flowing exhaust, and still be rather reliable
I would have just suggested looking for a good solid Diesel motored tow rig??
They just do the job so much better/more efficiently!
But we all like different things/
keep at it, and post as you go, looking forward to hearing how the finished deal
rides and get up and goes!
mrbb is offline
post #6 of 19 (permalink) Old 05-29-2016, 04:01 PM Thread Starter
01SSRedA4's Avatar
Liked: 24 times
Most thing I ever tow is a broken down vehicle in a bind, my camaro to the track a few times a year, atvs, and home improvement stuff. All stuff the gas 6.0 can handle with ease. Yeah no snow and no hills here so its gravy.
04 XR80 - Stock
07CRF50 - Stock
post #7 of 19 (permalink) Old 05-29-2016, 04:32 PM
Bryan's Avatar
Liked: 127 times
Awesome looks like was a fun project.
2014 Yamaha Grizzly 700 with Power Steering
5,300 Miles
Superwinch Terra 35 With Synthetic Rope
EHS Air Box lid
UNI Air Filter
1.5mm Shim Mod
Purple Spring
EHS Fuel Optimizer
Heat Demon Handle Bar Warmers
26x9 and 26x12 Maxxis BigHorn on 12" SS316 Matte Black
Canadian Yamaha Fender Flares
Plano 1510 Box
Join the Wisconsin Riders Group!
Click here for service manuals!
Bryan is offline
post #8 of 19 (permalink) Old 05-30-2016, 07:11 AM
Mudlover's Avatar
Liked: 86 times
Nice project. Looks like it turned out great. We have had a 2001 Yukon since 2007 and just recently upgraded to a 2005 Tahoe. They are great machines but you could never do a 4wd delete up here. We use it on the farm, and with the snowy winters it's a must. But I like that machine too just because it is different.
1993 Honda 300 2x4- Sold
Maxxis Bighorns on ITP Deltas
300ex shocks
2001 Honda 350 Rancher 4x4- Sold
ITP Mudlites
Jet kit
K&N Air Filter
1" Lift
Led cube headlights & 9 inch led bar
2000 Honda xr250r- Current Ride
Big Gun Exhaust
1987 Honda 350d Foreman- Current I have no clue what to do with project
Redneck Math: 4x4=Offroad
Service Manual Downloads:
http://www.hondaatvforums.net/forums...downloads.html
Mudlover is offline
post #9 of 19 (permalink) Old 05-30-2016, 07:54 AM Thread Starter
01SSRedA4's Avatar
Liked: 24 times
Unfortunately I'm having some issues with this new trans. It has a history of not working correctly, I knew this when I bought it, and I was hoping it was resolved. It looks like it is going back to the builder for another look. Right now it has no forward gears in D4 or D3. A little frustrating but I have all the confidence in the world in my trans guy so we will see how it plays out.
04 XR80 - Stock
07CRF50 - Stock
post #10 of 19 (permalink) Old 05-30-2016, 08:27 AM
mrbb's Avatar
Liked: 925 times
on the up side, at least your doing the work, as if it was at a shop, the labor would kill you. I got a new trans 2 yrs ago that had issues, , so feel your pain, they did make it right, but a pain in down time and back and forths to the shop.
I traded it in not long afterwards, on a new truck, which also has had trans issues, brand new and still JUNK lol
mrbb is offline
