Yamaha Grizzly 660 starting help!!! - Honda ATV Forum
post #1 of 10 (permalink) Old 03-17-2010, 07:01 PM Thread Starter
Hondalover96's Avatar
ok my uncle has a Yamaha 660 Grizzly he got it about right the time they came out, but anyways he had to get a new right axle on the front suspension(independent). So he never got the time to ever do anything with it so it set in the garage for 2 years.He got a new axle and he figured out it had stale gas in the gas tank.So he put new gas in. He also put new diff. lock oil and new engine oil. So he startes it up and the battery makes a buzzing sound. so he charges it up. so now the engines turnin over. he checked the spark plug and it was dry as a bone. we tried gettin it runnin on ether and it started up then shut off. we think its the carburator not puttin gas into the engine. does anybody know how to start this Grizzly please?
Hondalover96 is offline
post #2 of 10 (permalink) Old 03-17-2010, 07:09 PM
700xx's Avatar
Definitly need to pull the carb and clean it if it's been sitting for 2 years.
08 TRX700XX Silver/black, Uni air filter,L8ton racing 11/16" sway bar, 13t sprocket, Kenda kutters all the way around, Pro taper high bend bars, Powermadd hand guards, FMF powercore 4 & FMF powerbomb header, EHS programmer, EHS air box lid, Alba pro ellite nerf bars and bumper
700xx is offline
post #3 of 10 (permalink) Old 03-17-2010, 07:21 PM
I agree with 700XX, the carb needs to be taken off and cleaned. That's your problem.
post #4 of 10 (permalink) Old 03-17-2010, 08:01 PM
Billy250X's Avatar
Yep clean the carb real good.It's probably not filling up.
Billy
1991 Trx250X Custom exhaust,K&N jetted,widened 7.5 inches in the back and 8 inches in the frontWarrior rear shock and z400 front shocks with custom brackets.Race cut fenders.+3 swingarm.Way more to come.
Building things makes me happy.
Billy250X is offline
post #5 of 10 (permalink) Old 07-31-2011, 11:27 AM
mugs's Avatar
Grizzly wont start
I am having the same problem. Could it be a clogged fuel filter? I spray starting fluid into throat, and it runs fine. Seems like its not getting fuel.
mugs is offline
post #6 of 10 (permalink) Old 07-31-2011, 12:52 PM
Liked: 54 times
MUGS<<<<Welcome to the forums...Free downloadable manuals in the Schematics/Manuals section...Hondalover,and Mugs.....Remove the carb,dismantle it,thoroughly clean it,its jets,all orifices(avoid getting carb cleaner on anything made of rubber,o-rings,gaskets,float needle tip...
Deeperinthabush is offline
post #7 of 10 (permalink) Old 07-31-2011, 03:01 PM
69quadracer's Avatar
Liked: 10 times
Pull carb and clean, it's gummed up after sittin two years
69quadracer is offline
post #8 of 10 (permalink) Old 07-31-2011, 03:15 PM
Welcome to the forums. The 660 Grizzly doesn't have a fuel filter, but if you have the 550 or 700, it has a fuel filter. If you have the 660, then you need to remove the carb and clean it. Also, make sure gas is flowing from the tank to the carb, as the hose or pet cock valve might be clogged.
post #9 of 10 (permalink) Old 07-31-2011, 04:37 PM
jake72's Avatar
they sit more than a month or 2 and carb needs cleaned
jake72 is offline
post #10 of 10 (permalink) Old 08-12-2011, 06:23 AM
gottaroost's Avatar
I would take 'er easy with too much carb cleaner going in as that can quickly damage your internal rubber items in the carb---not worth it.
That carb will treat you well if it comes all the way out and all the way apart. The bulk of your problem lies in the jets, which are probably covered with varnish inside and out due to gas sitting for 2 years. Until you completely clean (or better yet replace because they are cheap) those jets, it will run funny or not at all.
Just last Saturday I had to do this EXACT same thing on a 2-wheeler that had been sitting for the magical 2 year stretch full of gas in the carb...what a mess...but the worst of it was inside the jets so I had to pay careful attention to it. It is just fine to use carb cleaner on the jets once you have them separated out of the carb itself...just keep it off o-rings and such.
If you are not a complete carb taker-aparter type, then at the very least get those jets out and clean or replace them.
2008 Raptor 700SE
2002 400EX
2010 Raptor 250
2008 Raptor 250
gottaroost is offline
