Old 02-10-2012, 08:22 AM   #1 (permalink)
Chef's Avatar
Member #2444
View Chef's Photo Gallery(0)
Cooling system......
Just an observation but I never see anyone ask about having problems, flushing, braking or just curious about the liquid cooled 420's and other hondas...
I cant download the manuels here at work but when should you change/flush your system??
2010 Rancher ES
1 5/8" PVC Snorkel
25" Mud Lite XL's
2" Super Lift
SUPER-winch
Chef is offline   Reply With Quote
Old 02-10-2012, 11:33 AM   #2 (permalink)
Chef's Avatar
Member #2444
Damn, must have been a good question!!!! 40 views and no responses!!!
2010 Rancher ES
1 5/8" PVC Snorkel
25" Mud Lite XL's
2" Super Lift
SUPER-winch
Old 02-10-2012, 11:41 AM   #3 (permalink)
cloudpump's Avatar
Member #14430
View cloudpump's Photo Gallery(0)
Depending on how you ride, I'd go with every winter. If you ride lots of mud, then I'd say every other month. But I have a habit of doing overkill maitenance
http://www.bjjboard.com
cloudpump is offline   Reply With Quote
Old 02-10-2012, 11:55 AM   #4 (permalink)
Ballast's Avatar
Member #8124
View Ballast's Photo Gallery(0)
Pretty much the same as a car Chef, what wears out is the corrosion protection not the freeze resistance or increased boiling point properties. Don't have the manuals handy but I suspect it's 2 years. Now they have the 5 year antifreeze I use that. Again it's the rust/corrosion prevention that's important.
4 HONDAS 4 ME
07 Rincon... 26" Mud Bug Rs, 1 1/2" rear spacers, 2500# Warn winch, Kimpex box, Moose skid plate
07 Rancher 420.... C Series Type 5 IPTs w/26" Mud Lites, Moose skid plates & A-arm guards, Viper winch, Kimpex seat, fender guards
06 TRX250EX.....Tusk nerf bars, White Brothers skid plate, AC Racing swing arm skid plate, Cobra A-arm guards
85 TRX125.... 1 7/8" trailer ball
Ballast is online now   Reply With Quote
Old 02-10-2012, 11:58 AM   #5 (permalink)
cloudpump's Avatar
Member #14430
See, I'm all about the overkill!
Old 02-17-2012, 07:45 PM   #6 (permalink)
bobs330's Avatar
Member #8144
Just looked in owners manual and all its says is ispect every regular service and have dealer replace if you are a numbskull. But most of us can replace it without a problem.
2011 Rancher 420 FPM
AMS Swamp fox tires
Stearns rear rack bag
Superwinch Terra 25
Moose rear bumper
Old 02-17-2012, 08:16 PM   #7 (permalink)
Dan G's Avatar
Member #11269
View Dan G's Photo Gallery(0)
I've never messed with a cooling system before, but I was reading in my manual I will have to jack the front end up to refill the system then burp it... Maybe your service manual will have a similar procedure?
Kawasaki prairie 400ish stockish
1995 honda fourtrax 4x4, stock.
Dan G is online now   Reply With Quote
Old 02-18-2012, 08:55 AM   #8 (permalink)
bobs330's Avatar
Member #8144
For the 420 all you have to do is remove a drain bolt on the water pump, and pull the burp tank off the back and drain, rinse it out and put it back on and reinstall drain plug. Then start refilling radiator, then start it and let it burp out the air till its full and then fill the expansion tank and your done. Also just an fyi, if you pull the thermostat to check it, its supposed to open at 176-183 F.
AMS Swamp fox tires
Superwinch Terra 25
Moose rear bumper
honda atv cooling system
honda atv cooling system flush
how to flush coolant on honda rincon
how to flush cooling system on honda atv
picture of rincon water pump drain bolt
